Hello,
A friend of mine spoke very highly of this site as it relates to friendly and helpful people with a true desire to share...other watch forums leave much to be desired when it comes to being friendly and helpful.  I'm excited to learn from those kind enough to teach.  Thanks in advance.
AJ
Hello AJ and welcome to the forum
lovely friendly place with help and advice given freely. Enjoy!
Cheers,
Vic
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
