Spot the defect
I just came across this and I just can't wok out what is right and wrong
https://www.ebay.co.uk/itm/361977951212
Apart from the fact that someone has sprayed the insides with oil, the repeat button is missing, the handle is bent, the platform doesn't match
1. I've never seen a carriage clock with a seconds hand
2. Why 2 seperate bells for the alarm and chime? And who would have worked on a clock like this and botched a new bell in like that? And is it normal to wind through the bell?
I can't decide if this is an honest clock that's had a hard life and worth spending some effort on, or if it's a piece of junk... but I'm sure Oldhippy will be along shortly to educate us all
10 hours ago, StuartBaker104 said:
Hmm, not sure why it doesn't show. Try this link
http://www.ebay.co.uk/itm/361977951212?redirect=mobile
or search for item 361977951212
Thanks
S
Its made in China and is utter rubbish. I see the seller mentions one like it sold on ebay for £400. If that is so the person has wasted money. The finish and design on this is terrible. The platform you can see is cheap and doesn't match. It's shocking. If a customer had brought it to me to repair I would tell them to throw it away.
Here's the one that sold for £400 http://www.ebay.co.uk/itm/Very-Rare-Collectable-Complication-Striking-Repeating-Carriage-Clock-/132125114708?hash=item1ec3454154%3Ag%3AqSwAAOSwax5YxUiS&nma=true&si=IWUFjdE7tY679NI1fi%2BJzmQXwdQ%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
The similarity is remarkable. According to the feedback, the buyer was very happy...
So what I can't work out is if this is a con artist in China trying hard to make something look old and spending the least possible amount of money... or if they just didn't know how to make a decent one.
It's obvious people that buy this rubbish know nothing about Carriage Clocks. These things are mass produced ebay is flooded with them. From what I can see the seller is doing nothing wrong. Look at the wording that is used they only say old carriage clock, any clock with a handle can be a carriage clock, the word old just means it isn't new.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
