Removing a Suspension Spring from a wheel F/S setting
Folkvisor
The suspension spring seems to be 'locked' into the wheel-type F/S adjustment assembly on the clock. Also, the screw holding the assembly is very tight so I don't want to mess with it until I get all the wheels off.
Is there a way of spreading the groove holding the top of the suspension spring? I think a movement opener would get in there but I don't want to break anything.
No wonder that guy didn't want to fix this thing. ;-)
Oh My have you got some work ahead of you.
The adjuster is easy, take off the Verge/Anchor, should slide right off.
Adjust the adjuster so it uncovers the one screw underneath the threaded rod.
Its off.
The adjuster can be cleaned assembled, just check for cracks in the spring.
I see the verge has grooves which need to be stoned and polished out.
And lots of bushings, oh boy, this is where the fun starts.
Agree with "altar' you have a whole bunch of work there. Looking at your pics the bushings certainly look suspect. I would give every part a real good clean & then inspect. A interesting project for sure keep us informed of your progress.
If you stone the pallets be very careful as this will alter the depth of the escapement and its action, it could even stop the clock or cause it to trip, (escape more than one tooth at a time) also be careful with the escape wheel and its teeth, check for any bure on the end of the teeth. You need to check the action first be for altering anything. If the action is good and this being your first attempt you could leave it alone. The steel used in these clocks on pallets is quite hard, not so on the rest of the steel work. The holes are meant to be a bit larger than the pivots in these movements as the wheels have what are called lantern pinons, they work better if a bit loose, clean the clock first then check the holes and pivots for wear.  Don't be to quick in stoning, study the escapement first.
I agree in my early days of clock repair I honed the escape on a french clock & the B**gger would not run because I had altered the depth.  I had to find another donor movement that had a replacement.
As a matter of interest I have always wondered if it is acceptable to move a worn/scored anchor escapement further along its shaft to the un used part. Your thoughts oldhippy.
I don't like seeing it. I know it is quite a common practice. The one in your picture shows to me what looks like solder holding the pallets in place. This is wrong and very unsightly. On high grade clock movements this should never be done.
Recognizing the job at hand is important to decide if it is within your comfort level.
In Dave's case, he's dealing with a robust American movement that is overpowered and parts have a wide window of error compared to a French movement where everything needs to be dead on accurate.
He is just starting out and beginning to see the details, I doubt he will stone the verge but the groove was on the landing zone, I could not see the impulse face. In any case, bringing items to his attention is a good thing. He'll decide what is within his ability and then move on. Most failures are not catastrophic, they can be redone until everything is ticking. I was told many times that if your not making mistakes, your not learning. Courage and curiosity will get us through it.
Al T.
Moving the anchor/verge over is the lesser of two evils. If you didn't bush the anchor or escape wheel.
If you did bush, verge to esc whl spacing may have changed, making a eccentric bushing would fix that and you might still move the verge over if your not comfortable with stoning the grooves.
Your the pilot in command so your decision is whats important. Having lots of tricks in your bag is what's important.
Al T.
The correct decision should always be made and changing the works or bodging up a repair is NOT the way to go. If you call this type of thing a trick I don't think Master craftsman in horology would be too pleased. I know I’m not.
For my education if shifting the anchor is not the 'best practice' and stoning the pallets will alter the depth what is the 'best practice'?
Stone the pallet and then reface them with a bit of main spring soft soldered in place to give the original depth again?
. You got it that is the correct practice. If done correctly, you will hardly notice that the pallets have been re-shod.
Well, thank you for all the encouragement.
I have a question: What is 'stoning' besides being a form of capital punishment in the Near East.
It's going to be an interesting project - that's for sure.
Good to know I have a group of people to rely on for advice.
It's totally covered. It's a mixture right now of distilled water, alcohol, ammonia and dish soap. It seems to be doing a good job because I can't see through the water any more.
I am planning on rinsing it, drying it and putting it in a wash of naphtha.
Will this plan do a good cleaning job? I was given the recipe by a clock repair guy in Winnipeg. Probably can't trust anyone from Winnipeg. LOL
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
