Hi
My name is Pete and Im interested in lots of watches but mainly ATP or at least till I track them all down. Im a retired engineer and mechanical things don't phase me so I thought these clock work motors would not be a problem. Well best laid plans and all that its been and still is a steep learning curve but Im getting there, more successes now than failures but the failures do still happen.
Pete
Hi Pete
Lots of Brits here. It's a very friendly forum and polite too.
There's knowledge, experience and ingenuity by the bucket load and they even welcome quartz bods like me!
Glad to meet you.
Neil from Newcastle
Hello again, Pete! Glad you are hear. Not being a Brit I had to look up ATP, but glad I did. Military watches have a large following, and these look like they'd be fun to collect. Especially if you can bring some sad examples back to life!
Have Fun
Hello Pete,
Welcome to the forum,
Great place here to exume the "failures" and have another go with the assistance of the pro's in the forum.
Cheers,
Vic
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
