Carriage clock no longer runs for 8 days
AlanCJ
I have an early 20th century striking french carriage clock which I have recently serviced.  I have a number of other clocks, a couple of 400 day clocks and a French regulator clock which I have serviced several times without problems, but this is the first time I have serviced the carriage clock.  Prior to the service it would run for 8 days on a wind, so I used to wind it on the same day each week, but since the service it stops after 5 days.  It is fully wound down when it stops, so I have no idea what has changed, can anyone shed any light on the problem.  It keeps good time, but I have had to adjust the escapement more towards retard than it was previously
Yes, that is exactly it, and yes I agree it is very odd.  I stripped it, gave it a good ultrasonic clean, reassembled and oiled with good quality clock oil.  It keeps perfect time but now stops after just 5 days on a full wind.  I had no problems with the service other than there was a mechanism on the mainspring barrel cap that I have not seen before and so I have no idea what it does.  I have attached a photo
What you have here is a stop work fitted to the barrel. This is found in better clock movements. I expect you do not have it set right so this is the answer to your odd problem. Here is a link explaining how it works. After reading it and looking at your stop work you find you still need help let me know.
http://www.vintagewatchstraps.com/blogstopwork.php
I am no expert and have never worked on clocks, but I believe the mechanism is known as Geneva stop gear/works or  Maltese Cross.
They have been on a couple of pocket watch mainsprings that I have worked on before.
You  are quite correct. It is used so the spring doesn't come off the barral arbor. That is why you give the arbor a turn before setting the stop, it causes a lock.
it is a Black, Starr and Frost (Department store in New York) branded French carriage clock which from my research dates it to pre 1920 when the company changed its name to Black, Starr & Gorham Jewelry and Silverware Company
It certainly seems as though it is not fully winding. I have not worked on Maltese cross or Geneva stop work but I suspect that is the fault area.
You quite often find part or complete stop work missing. The most common is the screw comes adrift the tread is worn or the stop work is worn and jams up the works. So parts go missing or just thrown away.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
