For the hobbyist, what would you suggest as a reliable and reasonable quartz battery tester?
Something that is easy to apply, accurate and moderately priced.
I don't mean the £1.99 free post Hong Kong battery testers!
To test the battery, just use any multimeter. But that is not normally needed, because if you work with quartz watches, you should have a new battery to replace, and one is interested in getting the watch to work.
Note, what has been linked above does not have a "line free" function, which is useful to free up watches that have got stuck old oil, (do not assume that is a so common case). It is also ridiculously priced. Check Ebay item 121926556898 for a model that has that.
Edited by jdm
jdm is spot on. I use a £30 quartz tester with line free. However the battery test bit is poor so I use a separate Chinese special. Mine only cost 99p
I don't though assume a new battery is fine. A quick test can save hours of grief. I was that man!
Cheers Neil
Yes, a new battery could be faulty. However I use a Japanese brand and never had one that it was. These come in boxes of 10 so any doubt is quickly dispelled popping another in.
a "multimeter"  (volt/ohm meter)  is not the proper tool for battery testing.   besides  voltage,  you have to put a load on the  bat..  these type meters are expenceve  and wear out.  new battery is the easy way.  vin
Never happened to me. Voltage under no load has always been a 100% reliable indicator of batter status, and my digital cheap meter works good as when new 20 years ago.
above does not have a "line free" function, which is useful to free up watches It is also ridiculously priced. Check Ebay item 121926556898 for a model that has that.
That eBay "economy" tester is what I have been using for years.  It has proved to be very useful, and at the price can't be bettered!
The one I pointed out is very close that I had in the workshop, Just to replace batteries back in the 70's. I hated battery watches and never repaired them, but at times I would just replace a battery,
Has anyone got the instructions for the one JDM mentioned above. I bought one last week and there were no instructions with it. Ta
Have a read of this thread:-
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.  Thanks for the link John, it will be interesting to find out how much it costs when they email me back.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
