Junghans Max Bill Dial Repair/Replacement
Hi Everyone!
I'm an aspiring watch collector. I've just started, and I'm only just looking for watch that really catch my eye with movements that I find interesting, and are within budget.
Right now, I'm looking at a Junghans Max Bill Automatic.
Model: Max Bill
Reference: 27.3500
Case No.: 706
Movement: Automatic / Automatic
Basic Cal. ETA 2824-2
Case Material: Steel
As you can see below, the watch is pre-owned and is showing a lot of use. That in itself is not a problem; I love how characterful well-worn watches look. But the dial on this watch is, in my feeling, beginning to affect the usability. A watch to me is first and foremost a tool; the dial is at that point where it is starting to prevent the wearer from getting the most use from that tool.
My question is this: Will this kind of scratching / damage likely come off with cleaning and general servicing?
And if not, are there places where I can source a replacement dial for it? I've briefly googled for replacement dials, but I haven't found any so far. Suggestions would be awesome.
Thanks!
Welcome!
I'm sure if anyone here knows a source for Junghans dials then they will share, but most of the time with vintage watches your chances of finding a replacement dial are extremely small. The same is true of hands for most makes, but Omega hands come up for sale from time to time.
Dials can be repainted, but factor in a minimum of £200 for a decent job... which at best will leave you staring at something a little too new and shiny looking.
I generally pass by any watch that has a dial I couldn't live with as is.
Hi Splat,
Any attempt at cleaning would only makes things worse.
I am usually not a fan of re-done dials but in the case of this watch I would say it deserves a pristine face.
The reason is that the Max Bill is all about the overall design and the dial plays a major part of the design in its minimalist starkness. Here, the scratches 'clutter' the dial and the beauty is lost.
Below pic is how it should look, compare it to the OP's post.
Having said that, good redials cost a bomb and the font used is unique so its probably easier said than done.
pic found on the web...
rgds
Anilv
Edited by anilv
Thanks, @StuartBaker104. I was after one of these a couple of months ago, but it was quartz so I passed on it. With the face of the dial being the most visible and contributing the most market value to the watch, this automatic example (without a date window :( ) is for sale within budget. Then again, there's that face. I may have to pass on it again.
I completely agree @anilv. Max Bill's bauhaus effort here is masterful. This is why I can only justify grabbing this watch if I could get the dial repaired reasonably well. And I think I'll pass on this for now. In the Philippines, I don't imagine there will be many professional shops that I could trust to do this watch justice. And I think a restoration of this kind needs to go to someone who is an "expert" in this model series. Someone who's already done it, and knows what they're doing. That font face is especially tough to get right.
The main reason for the scratches seems poor mounted and scratching hands. Hope you can do it better after sourcing a new or reprinted dial!
But my 1st idea would be: ask Junghans in Germany for a dial and/or send them your watch.
Frank
Edited by praezis
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
