Actually looks quite cool.
Anybody have one yet?
Magnet - Magic Wiper
For recovering small metal pieces or dropped watch parts
Tearproof & washable
Consists of 2 double-sided magnetic strips
Supplied flat
Folded dimensions: 285 x 82mm
Bergeon 7871
My daughter has a thing like that for cleaning the inside of her fish tank. That could be a far cheaper option!
What is wrong with a magnetic knife holder on a stick? I use one (the handle makes it looks like a T) and I don't have to bend over!
Because it doesn't have Bergeon written on it :D
Them fliers are a pain. Recently I purchased from a craft shop a A3 sheet of plastic/paper board that I have placed under my mat. I have found this really helps when looking for the flier. I also have a tiny raised ridge at the front of my work bench that has saved many a tiny screw from disappearing into the carpet.
I recently build a "parts catcher" out of a very transparent bag. I simply cut the bottom off so I could use my two hands one through each end to work on a watch I placed inside. I'm about to make a bigger one but I need to build a wire frame for it...
Hi all,
Just joined so this is my first post..
I have just received one today and to be absolutely honest I don't think they are worth the money!! all it is is a piece of card with a magnet attached so build quality is rather poor in my opinion...
Best wishes
Darren
Thanks Bob,
Very disappointed with this item from Bergeon, like everybody I have parts go flying and thought what a great item this would be, but when it turned up today I was left thinking why had I spent £12.00 on this...
Best Wishes
Darren
Thanks Bob,
Best Wishes
Darren
Thanks for the review Daz. Appreciated!
You are welcome Darren,
I know what you mean, I recently wanted to have a back opening knife other than the cheapo I got free with a purchase and bought the bergeon one. It is a good knife but believe me, it didn't open any more watches -- or better -- than the older, no brand, I had. So there went my $20! On the other hand, and to be fair, their screwdrivers are very good (but grossly overpriced like all the other good brands).
No problem WatchRepairGuy
I just did not want anyone spending good money on this and to be left disappointed upon receipt
bob - I know what you mean I just bought one myself (Bergeon again) as this was the only Brand I could find with Left handed blade the only others were the cheapos...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
