I've had enough trouble getting replacement watch hands to fit on some of my watches that I'm considering buying a set of broaching tools to help customize the fit. I have a couple of questions:
1) What is the right type of broach for hour and minute hands? I was planning on getting these: http://www.esslinger.com/broach-set-with-handle-set-of-6/ . Would they work? Are smoothing broaches preferred? Any other insights on proper tools for broaching hour and minute hands?
2) I also would like to broach second hands, especially because I have a few .22mm sub hands and those are harder to find than .20mm. I'm assuming I would need a "fine" set of broaches for that, something like http://www.esslinger.com/extra-fine-broach-set-set-of-12/ . But I believe broaching tools are tapered (a different diameter at the top than the bottom). This doesn't seem like a problem for hour and minute hands, but it seems like the pipe for second hands is long enough, that this would create a cone cut, where the bottom of the pipe may be too wide or the top too narrow. Related, I think you need to find the right spot on the broach to cut the right size and it seems like the opening at the top of a second hand pipe is smaller than the one at the bottom, which would prevent the broach from sliding through enough to find the right spot. Am I correct on this? Is broaching second hands possible? Any other insights on proper tools for broaching (sub) second hands?
Thanks much for any help!
Seth
I can only advise you with the type of broaches I used. I only ever used Bergeon there was not so many around in my days. There were two types 5 sided for cutting the other smooth. Smooth are used for burnishing the hole. Smooth are not needed for watch hands. You are correct about the pipe in a seconds hand, they are also a sod to adapt as quite often the pipe comes lose and turns while you try to broach the pipe out. The best way in overcoming this is to broach the pipe both ends.   A must is a tool that can hold the hand while you are working on it. The different sizes you need can also be put to good use as they can be used for re-bushing of a watch or pocket watches.
I hope this helps.
You have to be very carful with hands as they can go out of shape. Also only remove tiny amounts of material at a time, I use Bergeon smoothing broaches.
Do you find smoothing takes enough away to change the fitting? Also a drop of oil can help in the cutting.
Yes but it is slow but thats the point. I have found a cutting broach can snag and if not careful & twist the hand out of shape. Forgot to mention I also use a little oil.
Thanks for the great feedback. Sounds like second hands are just tough. I'm definitely planning on getting a broaching holder as well. Will update with results once I get everything lined up.
Thanks again,
Seth
Thanks again,
Seth
I just use a pin vice to hold the cutting broaches.
  • 6 years later...
When broaching second hands, it's important to take extra care and ensure that the broach is aligned properly with the pipe opening. You may need to experiment with different broach sizes or consider using files or other precision tools to modify the opening of the hand pipe if necessary. It's recommended to practice on less valuable or spare watch hands before working on valuable ones to gain experience and confidence in the broaching process.
If you need tools, I recommend a website that has various tools, https://www.moonzite.com. I often buy some of the tools I need from this site. The price is very cheap and the quality is very good.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
