Interesting watch to service. NO id but after a lot of searching found that this watch is a WW1 Trench watch & was most likely made by "excalibur" Hinged both from & rear of watch also this case  is 18ct gold
The Trench watch or wristlet was a type of watch that came into use by the military during World War I, as pocket watches were not practical in combat. The trench watch had to be rugged. Yet many trench watches were actually pocket watch conversions, with most having a clam shell back and snap on bezel. SHIELDS or SHRAPNEL GUARDS were introduced to protect the crystal of watches from damage due to life in a trench and not from artillery. It protected  the crystal from accidental breakage.
post-234-0-08700500-1406909652_thumb.jpg[post-234-0-19400700-1406909655_thumb.jpgpost-234-0-76000200-1406909656_thumb.jpg
Edited by clockboy
It's a lovely watch but I somehow doubt that it was an trench watch from WW1. If I'm wrong, I stand corrected, but I'm very sceptical about many watches of this type being military watches - unless you have actual provenance. You're welcome to read what I've written on my  watch web site at: http://www.willswatchpages.com/trench-watches.html - and, of course, you're welcome to disagree with me totally! :D
Thanks Willfly
It is just that the dates are about correct as this watch was handed down from her grandmother but not with the original strap.
It is really difficult to get an exact ID as there are no clear markings on the case but made in Switzerland is marked on the movement.
I found a web site selling this exact calibre watch as a trench watch so I presumed this was it.
I will have to do more research.
Edited by clockboy
Sorry Will the only marks that are readable are 18 with 75 at right angles which I presumed is the 18ct marks and stating that 75% is gold.
There are other really,really faint marks but I just can not decipher exactly what they are. I think the marks are letters G & S.
There is also a number 14002.
The case of this watch is very badly worn & battered.
Edited by clockboy
Interestingly enough, I've just bought a silver wrist watch with "GS" marking on the inside of the case - and it's not dissimilar in style to the one you show. "GS" in this instance stands for George Stockwell, who was a well-known watch seller and importer of movements from Switzerland. I'll have some better pics when it comes in.
This one dates from 1928.
If you can use a macro lens and get a good, clear close-up of the date mark, I might be able to get a date for it. It's probably got a London import mark on it as well.
Will,
Struggled with the macro photography as you will see attached
However found using a microscope some other numbers scratched on 38052
The case No. is 14002
Hallmark is really badly worn the first symbol has the shape of the letter C followed by the letter in lower case   r
Also leters G & S
The customer said her grandmother received the watch when she was aged 21 which we calculated as about 1928 ish
Edited by clockboy
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
