What about this.
oldhippy
Well where to start,
"This clock is a rare exceptional french original brass and champleve style enamel 4 glass regulator mantel clock, it has its absolutely amazing look to it all in great condition for age, the case has a superb original finish to it with only minimal age wear as can be expected"
The clock is certainly not of french origin the diamond trade mark was used by a Chinese manufacturer making both clock's and watches in Shanghai, the use of the word regulator is wrong it would depend on what definition of a regulator you would use but this clock could only be wrongly described as a regulator, its certainly not champaleve but he does say style so I will give him that.
As for it striking as it should I cant see it doing that at the moment with it set as it is.
The movement has a Brocot escapement and the quality of it could only be described as plain "Nasty"  a true horror of the horological world made from cheaply pressed out parts and finished by sweat shop workers on a dollar a day.
The description reads like a turd polishers dream but at the end of the day its still a turd.
It has however attracted a bid for twice what its worth.
Where would you like me to start?
1. Painted hands made from thick steel rather than thin blued steel
2. Brass screw to retain minute hand rather than washer and pin
3. What does "Trade Mark" mean on the dial? Wouldn't get that on a French clock
4. Pan head brass screws instead of machined blued screws or pins
5. Gong made from an old coat hanger
I'll let others continue...
28 minutes ago, StuartBaker104 said:
33 minutes ago, wls1971 said:
More than twice - it's got £20 postage!!
"You are more than welcome to personally collect any item free of charge"
 how very kind of them to allow no charge for personally collecting, but I personally find this next statement in the description truly unbelievable,
"This is a perfect investment clock and a beautiful display piece and a stunning brass, ormolu & champleve enamel clock which i am sure you would agree. Looks absolutely fantastic wherever it is displayed":wacko:
Everything in that statement is incorrect
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
