I figure it's time to start printing a logo on the watches that I build, so I designed this one today...
(yes, it kind of looks like cleavage :startle: )
Any thoughts?
I hate to be the wet blanket here but to me it seems a bit fussy,  could you simplify it a bit?  Less is more, sort of thing.
I can see where you are coming from as that was my first impression.
When I sat back and gave it some thought, I saw it more as an icon rather than just Don's initials, a bit like the movement identification symbols we see on watch movements. I am assuming that when used for advertising purposes it will always have the DJW Custom Timepieces written underneath.
I do hear what you're saying and also agree with you! I'm not 100% convinced that this will be the final design. I think it's close, but will probably tweak it a bit until I'm satisfied. I did, though, print it out on my laser printer at the approximate "Actual" size that would be on a watch dial and I was happy with how the logo itself looked.
The biggest problem with printing it at actual size was the overall amount of letters in the text. I may just shorten it to "DJW Watch Co."
This way I can increase the font size so that it is easier to read and won't take up anymore space than originally designed.
This wasn't my original intention, but this is exactly how I see it now!
I had to do something to fix the "Bosom" look to the logo!
Just a little space added to the "J" seems to satisfy my needs! Also, I found this Font online, which I really like!
Although the style of the Logo and the Font are totally different, I think they play well off each other. Kind of a Modern/Classical pairing...
Hi DJW, I like the full print very much but I liked the other logo -- the double-d cup -- better the way it was. Just in case you are using both...
New font is very nice,  just a thought but do you actually need the logo as well?
Now that I found this Font and because it is so artistic, I'm not so sure about keeping the logo...
Depends on how you do it. You could try something like...
It's the same principle - could even be in the same font as your "D J Watch Co."
Just an idea... all sorts of possibilities.
A small logo would look great just under the 12 on the dials!
One of the issues with designing a logo to print on a watch dial is how well does it translate to such a reduced size....
So, I took Will's advice and design (Thank you Will!) and added my own touch.
This one seems to translate the best...And I don't see the need to have anything printed underneath it!
...approximate look on a dial
Gets my vote!
It would look cool on a T shirt, black shirt & white letters.
Looks like I need to hire you as my Marketing Director! :money:
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
