A friend of mine, a retired watchmaker, asked me if I was interested in an old watch lathe.
Why he even asked I don't know [emoji6]
This what I received from him, an old Lorch lathe. Old but in good shape, no play at all. With a full assortment of collets. And the best part? I got it for free [emoji3]
What do you think? Still usable or just a piece of antique?
I actually was thinking of using it but first I have source a motor. Any suggestions for this?
Looking forward for your opinions.
Verzonden vanaf mijn iPhone met Tapatalk
It's very nice and very usable. The easiest option for a motor is an old sewing machine motor these can be picked up very cheaply on ebay and if you get one with a foot peddle you can have variable speed as well.
There is still an abundance of accessories available on ebay for these lathes but you have a good set of collets to work with its a Geneva pattern lathe you need to measure the collet's to determine if the lathe is a 6mm or 8mm version if you intend to search for parts at a later date 8mm parts are easier to source.
As it stands you should not have to spend a lot to get it running.
Thanks for the response. It is a 6mm lathe. I've already been searching around and it seems that the 6mm accessories are indeed a lot harder to find.
I've been looking out for a sewing machine motor on a local 2nd hand site, but no big offers there. So perhaps I should have a look on ebay. Any particular things I should pay attention on?
No any sewing machine motor will do there are thousands on ebay one with a foot pedal would be easier to use if it does not come with a foot pedal you will have to probably rewire it as most sewing machine manufactures use their own type of three pin power connector.
This is a example of what to look for,
http://www.ebay.co.uk/itm/SEWING-MACHINE-MOTOR-FOOT-CONTROL-PEDAL-BELT-FIT-LOTS-OF-OLDER-SEWING-MACHINES-/352101388920?hash=item51fae0d278:g:8yMAAOSw3h1ZVXGB
The best place to look for lathe parts is German Ebay they seem to get far more horological tools than anywhere else for some reason and quite often at a better price.
But I wouldnt worry about parts until you have it up and running and been using it for a while trying to jump before you can walk is very frustrating.
Yes but remember better 6 mm than 6.5 mm :thumbsu:
