How long is edit window open?
It seems briefly after posting there is the opportunity to edit posts, but the window quickly closes.  Anyone know what the setting is?  Personally, as someone quite prone to typos, I'd like it left open, but if its to close I'm curious how long one has.
thanks
Being a Mod, there's no time limit for me on editing any posts on the Forum, but - as I recall - it's only about 2-3 minutes before the edit facility closes.
There's a reason for the time limit on this sort of forum software - which is to prevent statements being altered. On other, more argumentative forums, this can be crucial. Luckily, we're not that kind of forum and, if we were, I and the other Mods would be wielding big sticks. This is a friendly and supportive site, for which I'm sure we're all grateful! However, the principle of letting original posts stand is a good one.
If there's something which you obviously need to amend with hindsight, contact one of the Mods and we'll check and change it for you - at no extra cost! :thumbsu:
Thanks for the explanation.  I'm on one forum that never closes and really like it.  Its maybe 5/10 on the augment scale (good guys but its technical so some really dig in on the need to be right).  No one changes posts, it's just the cultural norm, peer pressure I guess makes it unacceptable to do so.  Me, I make a lot of typos and skipped words., mild dyslexia?  hands can't keep up with brain?  whatever, but I hate just leaving them there forever yet its to frequent to bug someone about.   I really prefer the open ended thing, but I'm the new guy, so when in Rome.....:)
Even on friendly forums only allowing editting for a set period is needed.
I help manage a forum about toy steam engines and we had 2 incidents that made us change  from allowing editting for ever to about 15 minutes.
The first one was a refernce thread on screw sizes used on brands of steam engines. We had a regular forum member that managed that thread. People PMed him the screw sizes and he then editted his post and and added the information.
One time when editing his PC crashed and somehow it deleted everything from his post, about 2 years of work lost.
The other time we had a reasonably active member for what ever reason got upset and decided to leave, but must of spent a good hour or two editing every post he did and replaced his posts with either emojis or swear words, an extreme case of pettiness especially as we never even found out what upset him.
Either way only allowing editing for short periods stops this problem.
the  destruction of the  library at Alexandria  is very interesting HISTORY,  but nothing to do with watches.  the  author should have an opportunity to remove  it.  at  any time.     off color or argumentative  post should be  elimitated by a administrater.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
