What is it called? Hairspring Pin/Stud/wedge/plug...
Hi - I have a few old wristwatches, I'm transplanting the hairsprings from donor watches. They all have small brass pins/wedges pinning the outside end of the hairspring into the balance cock 'stud'.
This seems to be a fiddly job and I've managed to lose 5 of the pins so far (all sent flying to the four corners of the room, never to be seen again!). So I'm out of pins now.
I presumed these would just be called hairspring or regulator 'pins', but I see on the web that regulator 'pins' can also refer to the 2 vertical 'pins' on the regulator that the hairspring travels between.
So my question is simple - what are these little brass pins/wedges/plugs actually called so I can buy some (various sizes)?
I contacted CousinsUK to see if these might be correct 'https://www.cousinsuk.com/product/hairspring-collets-pins-wristwatch?code=S37391', but they seemed to know less about the product than me! There reply was 'We have followed up your query, however unfortunately the information you have requested is not available. All the information that is available is already on the website....'
As I mentioned I need a variety of sizes (diameters) if possible.
Thanks
Thanks for that. I've just been searching some more on CousinsUK and found something called 'Hairspring Fixing Pins', which seem to be exactly the same as the 'Hairspring Regulating Pins' I mentioned above (same code number, photo etc)... so I guess it must be those. I'm surprised Cousins Support couldn't tell me that though.
Thanks again
19 hours ago, Marc said:
Ah, the write-up regarding taper pins is wonderful- thanks!  I tried a few times to turn a replacement on the lathe and discovered it was nearly impossible to turn one narrow enough from brass; so I cheated and turned one from steel (fear not, the pin is installed in my daughter's Cinderella watch).
The assortment of hairspring fixing pins should give you what you want. They are used to attach the collet  as well as the stud. I have some that I've acquired  from various sources, but I think the next time I don't have what I need I'm going to follow @Marc's  instructions and make my own.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
