Placing a T-end mainspring back in the barrel - how to line the T up?
Hi guys,
I'm working on a watch with a T-end mainspring. The mainspring still looks good, so I cleaned it and wound it into my mainspring winder. The problem when I put it back into the barrel is that I cannot get the T to fit into the cutouts in the barrel and lid. I tried aligning it by looking through the barrel cutout and placing the T there before ejecting the spring from the winder, but it still moved. I assume that if I simply put the lid back on and assemble the watch, the spring will align itself when it is wound, but that would probably damage both the spring and the barrel.
How do you gurus do this?
Best regards,
Stian
This issue has been covered before on this forum. It seems you have to wind the spring with it cover off until it slides into position. I don,t know what spring winder you are using but is it possible to position the T end into barrel slot before releasing. The other thought is to hand wind the spring in.
Alright, seems the verdict is clear, although hand winding a mainspring seems very tedious in today's world...
Thanks everyone for helping solve yet another problem! This forum and its members are a fantastic example of what an online community can be.
Best regards,
Stian
Using a mainspring winder with T end Springs works great if you remember to leave a little bit of the spring out. so insert starting with the little bit of spring sticking out first in the barrel followed by the winder. Rotate until the T is over the hole. Then using, I usually use a large screwdriver push until the T is in the hole. Because if you don't get it in first it will not just magically pop in place all by itself. Then pushing on the T holding it in place you can now push the spring out and it will stay word supposed to be.
I'm a hobbyist who works primarily with early 20th Century pocket watches.  I had the same question.  I found a tutorial on the Internet Horology Club 185 web site (www.ihc185.org).  The tutorial was in the Forums section, listed under John D. Duvall's "Helping Hand Tutorials"  The program was titled, "Using the K&D Mainspring Winder."   http://ihc185.infopop.cc/eve/forums/a/tpc/f/7576090143/m/3446070753   The program provides a simple and logical technique for getting the T-end into it's hole in the barrel.  I don't know if it will work with the modern winders, but it works like a champ with the old style winders.   Good luck, Frank
I have amongst my many winders that exact model & it does work really great. If anyone see's one on the bay I recommend trying to purchase. The downside is it does fit small watch size barrels.
  • 4 years later...
Edited by Kalanag
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
