I don't like it to begin with but have bought it to practice on and ended up learning how to deal with fake watches, which is also part of the deal, just in case I'll have someone comes with a fake watch.
If anyone comes along with a fake watch. You should simply turn their custom away [emoji16]
Sent from my SM-G920F using Tapatalk
40 minutes ago, digginstony said:
I use the Horotec screwback case opener and is excellent, if not particularly cheap. See picture. There are cheaper non branded options on the market. In my opinion I wouldn't waste anymore expenditure on a jaxa type opener 7b87e42a70b7162408d1563529e4c2ce.jpg
I've learned my lesson of buying garbage and in fact, I've done it because of, to begin with I just started changing batteries and as I've said in the past just unknowingly got hooked into this hobby, and already started to order some real tools and not toys.
Yep we have all been there. But there are decent non branded stuff out there. I made the statement that I would never buy anything Chinese, in a "Load bearing context" but have recently acquired a water pressure tester. It's a Chinese copy of the Bergeon 5555/98 and it's excellent !
There are very good Chinese products and very bad ones as well. You need to have track record with a particular manufacturer in order to know if you want to buy his products or not.
I would say over 80% of Chinese tools I've come in contact with, were inferior either functionally, ergonomically or sub standard materials. But every product should be individually appraised. Never cut costs on tweezers. I prefer Dumont but they are not cheap. But back to subject. Consider a bench type opener and as Clockboy said, the Horotec will open anything
Thanks for your advice. I agree with you about the Chinese products,  and the Horotec is on my future shopping list now and in after reading all of the members input here, I am even scratching the Bergeon's Jaxa tool now, and save my money for the better one.
On 9/5/2017 at 0:55 AM, digginstony said:
I would say over 80% of Chinese tools I've come in contact with, were inferior either functionally, ergonomically or sub standard materials. But every product should be individually appraised...
There is an entire thread dedicated to bench case openers, which can be found using the search box on the top right. The consensus, bases on multiple postings, is that the Chinese do work perfectly, for a fraction of the Horotec or Bergeon tools.
At $5 a piece, is not much money saved. Beside, actually they have different uses, the Jaxa opens and closes just fine a good 90% of screw back watches, and is much more practical and handy to use. No hobbyist should be without one.
Edited by jdm
Good to know. Thanks for the info.
  • Similar Content
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
    • Can anyone help me identify this watch/pendant. It was inherited by me from my grandmother and I am unsure as to what it is. It's a watch/necklace with a blue face with the inscription "INGERSOLL" and "Swiss Made". Have tried looking online but to no avail. If anyone knows a make/model or knows where I might be able to find out about it, that would be very helpful.
