JD Ricahad,
Yes, those are the type of lathe belts I can't stand. They are the very reason I switched over to O-Rings. I went through the learning curve with the welded belts as well. Even a welded belt that looks perfect still has a hard spot at the seam. I know that some people swear by welded belts but I prefer the seamless O-Rings.
david
Edited by david
JD Ricahad,
david
I will get one so i don't go through the same annoying learning curve. All little sounds bug me:)
I'm an o-ring fan too.
Inside the lid of my Boley and Leinen lathe is a stuck on label which says it is essential to use first class mineral (or spindle) oil.
After some research (where I came across as much opinion as there is about watch oils) I bought this:
http://www.ebay.co.uk/itm/Mobil-Velocite-No6-High-Speed-Spindle-Oil-Free-U-K-Postage-/321918165229?var=&hash=item4af3d160ed:m:mA1wRjMUae9aNleEfui4_lQ
For those who care about such things, this is the same oil as is specified for the spindle on Linn Sondek turntables.
This looks like someone filled some plastic containers with Mobile oil and printed some labels. No way any company label a product like this ebay stuff.
Used to sell the stuff and the smallest package was 25 litres!   Maybe they have decanted from this but I bet Mobil will not be pleased to see their brand name used as such.:mad:
If I used my lathe all day every day for the rest of my life I wouldn't get through 25litres of spindle oil, so whilst I knew this had been decanted it seemed like a great idea to me :woohoo-jumping-smiley-emoticon:
I also bought a plastic syringe to fill the oil cups.
re urethane belting, the challenge to a good joint is alignment and also to let things sit undisturbed until it cures.  The later is really important on small belts.  I was having a terrible time getting a good joint with 3/32nds belting I used on a pivot polisher and spoke to the manufacturer.  The suggested letting sit overnight which made the difference.
Here's a fixture I made.  It holds the belts in perfect alignment which is important for vibration free operation.  After curing (usually 1/2 an hour) the excess material is trimmed away with a nail clipper and sanding board (if necessary).   You get smooth running joints you can't pull apart.
Its a very simple thing, 4 pieces of 3/4" sq cold rolled steel with reamed holes for dowels.  2 sections form a clamp.  With both belt ends clamped with about .100" sickout out, the two haves are brought about 1/4" apart.  A hot blade is placed between them, the are brought together and you can feel when the belt melts.  Pull the blade out, squeeze together, hold gently with a C clamp and wait
