I am working on a Seiko 7002-7000 diver...the bezel rotate freely and does not ratchet...that is the problem....my supplier says that no bezel spring is listed for this watch...does it require an entire new to bezel to operate correctly...what am I missing...thanks...
Hi Jerry,
There is a little detent spring ball fitted into the case that should press against the underside of the bezel. This is probably seized and stuck in the down position. Try getting some release agent and put a couple of drops on the top of the ball and let is sit for a couple of hours before trying to free it off with a small screwdriver or pick. If that doesn't work, remove the movement from the case and put the case in a small jar of release agent (Plus Gas), and put the jar containing the case and agent into an ultrasonic cleaner and give it a good blast. You may have to do this a couple of times.
http://www.ebay.co.uk/itm/Plus-Gas-Lubricant-Spout-Tin-/360697911631?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH&var=&hash=item53fb45594f
I hope this helps.
Edited by Geo
Occasionally the ball and spring go missing through wear and corrosion. I have made replacement springs from cutting down a spring from a spring bar, the ball can be found on fleabay. Additionally there is an o ring in the bezel, again these can be sourced on fleabay. The whole lot snaps back together easily enough with a smear of silicone grease, the ball and spring will stay in place one reassembled.
Based on the description that no ball and spring are listed for the watch, I believe the system uses a ring bolted to the case (normally screws are at 4 and 8, bump is at 12). Somewhere in the ring there is a round bump that doubles in function for the ball. It is also possible the bezel is not unidirectional as some original/certain model of Seikos were made. The ratchetting is basically due to the contact of the serrations underneath the bezel against the bump of the ring. The serrations (gear like) are sometimes angled so it will be easy to go in one direction but difficult to go in the other direction. This system can be found with and without the angled teeth on the bezel which will make it unidirectional or not....or so I've found in some old Seiko cases. I forgot to say, the ring is the spring!
Edited by bobm12
The 7002-7000 had a uni directional bezel. A good article can be found here:http://forums.watchuseek.com/f281/how-buy-seiko-7002-diver-collectors-buying-guide-258086.html go down to the sub heading Bezel and look at the 2nd picture showing the click ball between the 1 & 2. The click ball and spring are part of the case and were not supplied by Seiko as separate parts, as they were riveted in place. However these do become stuck and sometimes fall out, the o ring perishes and the whole lot fails. It normally just takes a clean, new o ring and a dab of silicone to get the whole lot going again if the click ball is still there. I have restored a few of these now and have had to fit the click ball and spring on a couple of ocassions.
Here is a picture of the parts involved. It varies according to the 7002 generation so instead of a bump you will find a little kind of arm or something similar sticking out from the ring.
We were posting at the same time! So, maybe my terminology is different but the idea is the same :)
Hope it helps.
Edited by bobm12
The first generation 7002's 150 metres, caseback code A1, used the ball and spring these being:
7002-7000
7002-7001
7002-7009
7002-700A (blue and red bezel)
7002-700J (Japan-only version, with "17 Jewels" on dial, blue and red bezel)
The second generation 7002's upgraded to 200 metres, caseback code A0, used the bezel spring as shown on the last post these being:
7002-7020 (200m model with a steel Tag-like bezel design similar to the SKX171 model)
7002-7039 (200m model, in black as well as blue-and-red bezels)
Even more info can be found here: https://archives.makedostudio.com/seiko-divers/
Edited by Blacklab
It will be a bit fiddly, but you should still be able to fix it Jerry, assuming you can get a ball bearing of the correct size.
Remove the spring and with a very fine round needle file dress the hole until you remove all traces of the original crimp. Put the spring back in before trying to see if the ball fits the hole properly, or you may not get it out the hole again.
Once you have the hole sorted out you will have to make sure it is clean, then lubricate the spring with some grease and place in the hole. The next bit is the tricky bit, you will need a punch with a hole in the end that is a about 0.010" to 0.015" smaller than the diameter of the ball, you might need to modify it to prevent catching the case in the wrong place by grinding a small flat on one side of the tip. Place the ball in the and of the punch, holding it there with a spot of grease. Now using the punch place the ball in the hole and press it right down until the punch touches the case evenly, then give it a sharp tap with a hammer just enough to deform the hole and retain the bearing. The case will have to be rigidly supported when you do this.
If you do not have the equipment to doe the above, you could clean out the hole grease the spring and ball the carefully try to snap the bezel in place without the ball flying off into oblivion!
I hope you manage to fix it.
Edited by Geo
I think I understand this but Geo, just to clarify for me, that's swaging or staking the outside of the hole to retain the ball?
Correct, it takes very little to hold it.
You don't actually need to crimp the hole, 2 of my 7002's bezels just sit on the ball/spring and haven't come out as the bezel will retain the ball. You can get the balls on fleabay (just type in Seiko click or Seiko clicker) or use a ball from a ballpoint pen as shown here: http://derekbartle.webs.com/apps/blog/show/2907522-how-to-get-that-click-back-in-your-6309-7040 yes I know its a 6309 but its the same system.
That's good news, it's a far simpler option than my first one. Good call Blacklab!
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
