PS I just realized the toolmakers block they're sitting on (its 4x4x4) is one of a pair I made and they were sent out for a commercial case hardening and then I ground them.   They are suppose to be 50 thou deep.  All the tapped holes were plugged to avoid hardening the threads.
Edited by measuretwice
Klassiker,
The questions you asked are great questions and questions that should be asked.
First off, annealing can be a long precision process. Most watchmakers have come up with various home grown methods over many years. There are some videos by Steffen Pahlow where he anneals material with an alcohol lamp. It has been awhile since I have watched  it but I believe he encased the part with some brass tubing and heated everything with the lamp. I have a computer controlled kiln that can reduce temperature in controlled increments over time. The kiln was expensive and is probably not on the wish list of most watchmakers. The main concept is to reduce the temperature slowly, in steps, over a long time period.  Most watchmakers do not have hardness testing equipment but you will certainly know if the material is "soft" when you machine it.
Drill rod is a generic term for small diameter shaft material that has been ground on a centerless  grinder. It is generally offered in Inch, letter and number diameters in relitavely  short (3 foot)  lengths. It is usually offered in oil hardening (O1,O2), water hardening (W1,W2), and air hardening (A1,A2) steels. The O,W and A designators refer to the chemical composition of the steels. It also implies that the steel is to be hardened by quenching in oil, water or air. Since air quenching has the least amount of temperature differential, it produces the least amount of distoration and cracking in the quenching process. It is used a lot in high precision applications such as stamping dies. Water hardening tool steels are far less expensive then the oil and air hardening steels and are used in lower precision applications such as knives and scissors. For some reason the W composition of drill rod has become the favorite for watch staffs.
david
On 11/20/2019 at 6:07 PM, measuretwice said:
I probably wouldn't case harden a part like that, easier to grab a piece of tool steel, heat and quench.
Ok, let's make another example. Let's say I want collets like the below to cut holes in straps.
https://www.cousinsuk.com/product/hole-cutter-rotating-6-punches
I suppose they should be hardened just like a notch cutter: https://www.cousinsuk.com/product/notch-cutter-pliers-cousins-swiss-style
In my EU country only structural, stainless and leaded steels are available retail. I can still buy on Ebay of course, most sellers are from the UK but is not like they carry any US type like O W and such letters. There is no heat treatment company that does retail work. So far I've found that turning leaded stock on my small lathe produces acceptable results, not so much for structural, and I'm not even trying stainless at this time. These are my constrains, and of course a reasonable budget. How to proceed?
Punches like that should not be from mild steel/case hardened,  it pretty much has to be tool steel, through hardened and tempered.  Its super easy to do, propane torch and a can of old oil.
You're going to have to figure where in your market to obtain materials.  Google what your equivalent is of O1 tool steel is in your market then google for who sells it.  Its so common, there has to be some service centre (what places that sell metal are called) selling it - either bricks and mortar or online.   Here (and in the US and I believe overseas as well) we have Metal Supermarkets which was started by friend of mine, Bill Mair.  There are numerous mail order equivalents and lots of small independent service centres.  Anyway, in a place like that, everyone of them will have O1 drill rod (silver steel in the UK) or its equivalent in a little rack by the cashier.
Silver steel should be:
US 1021 = EU C16, C22 =  UK 070M30, 080A15, EN3B (mistakenly I wrote mild bright above)
I understand that in the US there have local and postal materials shops (plus an infinity of other goods and service), but it is not so in Continental Europe, as mentioned the best sellers are in the UK only, otherwise your choices are limited to what I mentioned above, plus some copper, brass and few more.
where are you located?  Wouldn't ordering from the UK work?
Sorry I can't help more help; I'm not there and have not bought metal in Europe.  However I can't believe its that hard to find.  Anywhere there is any manufacturing there's a supply chain that includes MRO quantity metals.  O1 drill rod is so common you can get here at any place that sells machinist tools
Here's a couple of MRO style service centres from a quick search
https://www.metals4u.co.uk/
https://www.metalsupermarkets.co.uk/
I get most of my parts from the UK, and same was for auto parts before, plus other things.
I understand that certain things are difficult to believe for Americans that aren't familiar with other countries. For obvious reasons in certain ways the UK is the one that is most similar, yet is very different believe me. In my country who sells a something won't sell another, there is very little interest in machining, model building, etc.  There are no machining college courses, or the like. The watch repairers association doesn't even have a website. Modifying vehicles in any way is illegal, no exceptions. Petrol fuel can be easily USD 7.50 an US gallon. And I'm talking a country that is still 2nd in the EU industrial production, you can imagine about the others.
Sounds frustrating, but I know there are other aspects that make up for it.   I get its very different, been there several times, have one kid living there now and the other 3 all have lived there as well so I've some exposure, I'just never bought metal there.  Wife and kids have been everywhere there, most often I'm left at home at the salt mine to pay for it all, they take me along occasionally.  Will be back in the spring for the baby's graduation.  As a tourist, that probably gives lots of visibility of the positives but not so much so on the day to day negatives.
Still, there is manufacturing, so there must be an MRO metals supply chain.
PS, You're technically correct, Canadians are Americans "(as in North American) however in the common vernacular here "American" means someone from the USA.   I'm from and am in Toronto
Both MSC and McMaster Carr have an international sales base. There should be a way to purchase material from them almost anywhere in the world.
I was not aware that Kasenit hardening power was no longer available. I checked the internet and numerous other suppliers offer a similar product that should be available from MSC or McMaster Carr. These companies also supply drill rod.
One case hardening technique I used in the past was to put the part and Kasenit powder into a crucible and heat everything together. The Kasenit would melt into a cherry red liquid along with the part. I then quenched the part in water. Experiment and see what happens.
david
David, just to make it more clear, it is that not that one can't buy materials in Europe, or that they are not made here. Of course one can buy from the Internet if willing to pay all the extra costs associated with that and are OK with the absurdity of importing what is also locally made - but not available in retail.
My country has large steel processing factories. It produces special steels and alloys, sophisticated machinery, ships, trains, airplane parts and very fast cars and bikes. But all this is exclusively for industrial or commercial use. There are no sellers of machining tools or materials that cater to individuals or online, only few individuals sell on Ebay, but they have very limited inventory. And the reason, as I said before, is that model engineering or home machining does not exist as an hobby here in continental Europe, and If ever did that ended decades ago. If someone is trained or has the passion will possibly get a job in that sector, not even so well paid, will come back home tired, and that's it.
Few years ago I went to a local Makers fair, you should probably know about this tendency. All what was there were drones, 3D printers, and Arduino electronics, almost all made in China save for some from northern Europe. Nobody showed metal work, and I understand that, as it's something that makes noise, dirt, requires a large dedicated space, electrical, etc. But most people in Europe, even wealthy ones, live in cities and apartments, not houses with large garages or sheds. Young men, even the technically inclined ones have different interests than maching/ fabricating / modifyng / fixing things, especially when they learn that they won't get much money or appreciation from it.
I have to agree with jdm (btw. what is your country?), getting a ton of steel is no problem here, but getting a 1 meter rod is. At least the supplyer will charge his minimum fee which is equivalent to several 3-m rods.
However "silver steel" is available at many online model engineering shops.
Frank
    • Books, or some sort of voucher to a material house if they do them. You can never read and learn enough and if you find a material house that could do a gift card then the person could pick things they really need.   Tom
    • I don’t know what a pivot locating tool is? I am not a clock guy though but everything else you mentioned cousinsuk should be able to supply without issue. you might get more results if posting in the clock section of the forum.   Tom
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
