Finally got round to taking my Brother in laws Rotary apart to glue all the chapters which had fallen loose back on. Unfortunately when I went to put the very small pointers back on to the chronograph dials I realised that they both still had the ends of the pinions still inside them and I had sheared them off when removing the pointers. The movement is a Miyota and I will get another but anyone know how to get those pinions out of the pointers the hole is smaller than anything I have and there is little or nothing to grip. The pointers themselves are only 3.5 mm. I am starting to think I should just get new pointers.
Cheers Vic
That's a real nuisance Vic, it looks like it will have to be new hands. As a matter of interest, are they drilled all the way through?
I am having second thoughts about this now.  Looking at the myota 6P50 pictures on the internet there are actually no projecting pinions.  I am now wondering whether there is too much glue on the back of the dial holding it too far away from the movement.
Either that or I am just being cack handed.
Hi Vic,
Are you sure it's a 6P50?  I don't see that movement listed in my list of Miyota Tech Specs, but I may not have a complete listing.
I did find this one (PDF Attached), that looks like your movement, the Miyota 6P21, and there are definitely pinions for the hands.
I hope this helps mate:
Miyota _6P21.pdf
Cheers Lawson,
I got the PDF for the 6P50 from the Cousins download site and I have the old one I knacked up which is marked. There are a couple of places that sell them but I am waiting for my preferred supplier to return from holiday as I am not in any rush.
I know now why Mark seems to use two levers instead of the presto style tool.  The pinions are apparently .17mm diameter and I am 16 stone - no contest really.
I had a look at your PDF which is better in layout than the Cousins one and similar enough to verify the problem.
Thanks for the help.
Vic
They are the originals George, couldn't have managed without the scope though.
Cheers, Vic
Cheers, Vic
Very well done Vic.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
