French Mantle (Slate) Clock Movement
Folkvisor
Smooth snail wheels are machined in such a way that with each hour the rack drops down a tooth at a time, the only difference is its more difficult to see and judge. With many movements the minute, hour and sub wheels are marked by a small punch mark, have these lined up and all should be correct.
The strike wheels with pins need to be in the correct order. Imagine a clock face and you are looking at it.  The wheel next to the fly should have the warning pin at about 9 45 or 9 50. The gathering pallet wheel with its pin should be resting on the stop leaver inside the movement that is the lever just above the hammer lever. The strike wheel (the one with loads of pins in) should be clear and not in any lifting position of the hammer lever. The gathering pallet should be attached onto the extended pivot at about 10 to the hour (you can always move it if need be) You should have two pins set in the back of the minute wheel, which lift the lever (red arrow) this will lift part (green arrow)The rack will drop down onto the snail, these levers at the time of working also release the wheel next to the fly wheel with the single pin against the guard which is attached to the lever  (red arrow) inside the window (blue arrow). This is called the warning, note the hammer at this stage should not be lifting. When the clock is at the hour, lever (red arrow) will clear the pin on the minute wheel, the guard will also drop causing the strike wheels to rotate. Depending where the rack drops onto the snail will depend how many times it strikes. If there is no punch marks on the wheels, you need to have the rack dropping down for 12 0’clock about here (yellow arrow)
I know the photo I’m using is for a platform and not a pendulum, the striking is the same.   If you need more info just ask or if you don't understand.
Edited by oldhippy
That's a new one for me I have never seen a smooth snail wheel before. As you say it must be difficult to  get the sequence correct.
I guess I just lucked out getting to work on a clock with a smooth snail wheel.
Have you any idea how old such a clock would be? Ballpark...
It is impossible to get this kind of information in books or on the net. If not for this site there would be nothing at all.
You should write a book.
Edited by Folkvisor
Now to regulate it. Providing the springs are good this should keep very good time 1 minute in a week ether way. Once you learn about the striking, these clocks are quite easy to work on. What takes the time is the polishing, cleaning, and bluing screws.
  Happy to help anytime.
I'm still trying to get it to speed up a little more. small increments. I'm sure I'll be pretty slow when I'm 120 or so years old too.
The pins on the minute wheel aren't any too long so I have to be really careful about pulling off the minute hand or it will pull the pins away from the lifting lever. I'm not sure that I can do anything about that except making sure the pins are in place before I put the clock together.
I'm learning slowly. Someone did a lot of thinking figuring this stuff out!
Yup. I've found about wheel alignment from experience. There's lots to learn. I'd like to get a French Clock of my own to work on so I can learn more about them.
They want me to fix a grandfather clock but it doesn't look much different than my mantle clock just weights instead of springs and a moon phase 'clock'. Also,  there's lots of info on line about them...unlike French clocks.
Try and get your hands on an 17th or 18th century 8day English Longcase (grandfather) clock. They are wonderful to work on, in my time I must have restored hundreds. French carriage clocks are interesting too, because after all that cleaning, polishing and bluing screws people actually see the clock working, some do have complicated striking.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
