Just recently bought a K&D 18 Inverto staking set on eBay, all the stomps are complete and it just missing a few stakes.
The staking set included this weird looking stomp with a tightening lever (it seem like it) try to google for some info but failed to identify it.
Attach is the image of the unknown tool, if I may add I also want to know the purpose of the 10 pins placed alongside the stomps (highlighted in red)
Thanks in advance
What you have is a incomplete combined jewelling and staking set , it is perfectly serviceable as is as a staking set but there are parts missing which will make it useless as a jewelling tool,  the pins are for pushing out friction jewels, the other odd looking part I have no idea but if its Kendrick and Davis it will probably be on the following site somewhere,
http://kanddinverto.weebly.com/
Of the items in the staking is set circled should be the reamers for the jewelling attachment for the staking set that casually appears to be missing? Then the ministry tool is also missing something. It's known as a Balloon Chuck may go by other names and other parts of the universe. It's used to hold a balance wheel in a lathe they can polish the pivots. Which without a picture showing it probably makes no sense at all by my description. But I did find you a picture online at least showing the balance wheel in the tool.  You do have to scroll quite a ways down the page but it's there.
http://www.geocities.ws/dushang2000/Lathe Tools/Lathe Tools.html
Hi Wls1971, ahh so its for pushing friction jewel, so not only the stakes are missing also the jewelling attachment, anyway I have a Seitz jewelling tool so should be ok, is the jewelling attachment sold separately or as sold together with the set?
Hi JohnR725, it looks like the balloon chuck for the lathe you mention. oh well, I guess I have no use for it.
Thank you both
doesn't there have to be a hole in the black disk for its use as balloon chuck?  Or were they sold this way and the user made the hole?
It looks a lot like this, missing the centre bit....from an article on balloon chucks, Horological times june 2010.
I've attached some additional images you can see the variations in design. The one that has the screw off end the ones I've had I've never had the hole centered. Then the other image with text explains a little of how to use it.
Kendrick and Davis made  two friction jeweling attachments that could be retro fitted to various older frames and to the 18 series of frames the attachments where cataloged as a 540 and 540R, thats what appears to be attached to yours but minus the lever and micrometer adjustment.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
