Dating an Ansonia Slate Clock
Tmuir
I recently picked up this rather sad looking Ansonia slate clock for a quite reasonable price. (The seller counted my offer with an offer $50 lower than I offered to pay)
Other than a missing pendulum it is complete.
I've not looked too closely so haven't decided if someone painted the slate to try and make it look better, or its just filthy, but by the weight of it its definitely slate
Are there any Ansonia experts that could date this or give the model name? I'm guessing 1880 to 1890, but that is just a guess.
The corners and top that look to be hand painted badly gold, would this of been originally painted gold, or gilded?
I do like the enamel dial and can see the potential under the grime, and yes it will need a number of bushes.
I do have the gong too, it had become unglued from the clock, so it is not sitting inside the movement
Edited by Tmuir
The link I provided is what you needed. If you look at it again you will see the label of 1883 up to 1929 Ansonia where produced at Brooklyn, New York. Your movement is stamped Ansonia Clock co New York. One other thing if the glass is thick and original it will be from the early period. Thin glasses were fitted later. You also might find more info under the dial.  The hands are a style called  fleur-de-lis which is a French style which means Flower and are very popular with French clocks.
Clockboy you are correct these American clocks are not in the same class as French movements, there made of soft steel and poor grade brass. The reason these movements had lantern pinions was to take the wear and tear of the extremely powerful springs, the old springs are also made of poor metal. I don’t know if this is true I was told the reason the main plates are skeleton was to save on cost.
I would agree definitely after 1883, although it would be nice to tie it in tighter than that.
I remember reading somewhere that these clocks were made to counter the french slate clocks coming into the US, Ansomia also made cast iron clocks painted to look like slate and cheaper wooden cased clocks painted to look like slate or marble too.
As oldhippy says not as good quality, or worth as much as the French slate clocks, but still interesting none the less
Yes you are right.
  • 4 years later...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
