Wow, what a fascinating thread, and very encouraging (despite the lost screw). Perhaps get a stronger magnet, one of those neodymium monsters?
My first strip down will be of a virtually identical watch! I haven't started yet because my tools supplier forgot to include the Bergeon screwdriver set :-( The most expensive item it was too, mutter, mutter...
I use one of these... never fails... trouble, it usually picks up the fridge as well...
Edited by WillFly
Success, well, that's the movement side done with a ticking balance wheel.
I have mislaid the crown wheel washer which makes winding a bit more like grinding.
And many thanks to Geo who kindly supplied a spare jewel holder screw.
Its back in the case and running fine.
I'm very pleased with my first strip down. I've lost a screw and crown ring washer but all in all a good result.
Has anyone else stabbed themselves with an oiler? They might be thin but they're **BLEEP** sharp, my thumb is throbbing.
Phil
Very well done Phil, it's a great feeling when you have your first success and to achieve this with the first watch you stripped down is truly excellent. I look forward to hearing of more success in the future.
Thanks for you help Geo. I have a Seiko automatic that needs a clean, but that's after I find something better to store the parts so I don't lose them.
Highly recommended (the storage)! Great job Phil, and on your first watch!
What happened to the crown ring? (You are talking about the bushing I believe). Did you sourced another one?
Edited by bobm12
Yes I've mislaid the crown wheel washer, I've no idea if I lost it taking it from the box today, or whether I lost it last week when I put everything in the box.
Phil
Not the oiler..... but stabbed myself on the forehead with very pointy tweezers, whilst trying to catch a loupe falling out of my eye ......... TWICE ........... :(
That's so annoying when that happens: the tweezer points get bent out of shape when they hit the bone :(
Pro Tip: try not to poke them in your eye instead though. The eye is much softer, so the tweezers will be OK, but it's not so good for the eye.
Edited by colinh
Phil your doing great. I'm reading along and see you're getting excellent help from everyone. Just keep working steadily and taking those pictures! You'll definitely need them as reference later when you reassemble. Great work so far!
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you!
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
    • This eBay listing seems to verify that the watch disassembles as I suggested : here. The display caseback is held by the section that pushes out of the outermost rear bezel.  The movement seems to be a Ronda 1113. Best Regards, Mark
