When I've demagnetized a watch, I've done it before taken it appart. One way of knowing if it needs demagnetizing is by using a compass. If it, when placed under the watch and moved away from it, gets oriented/moves towards the watch, then the watch should be demagnetized.
The reason to demagnetize the movement when inside the watch and before servicing, is because of:
1.- the hairspring is protected since it is held in position so vibrations should not affect it too much.
2.- If there is any debris stuck to the movement, they are released as the watch is demagnetized. Therefore, cleaning is "more" effective. The released particles go with the cleaning. If demagnetized after maintenance they act like sand paper screwing up the parts inside so to speak.
Also, when demagnetizing, the hairspring becomes very hot and may loose its temper so some demagnetizing tools are simply too powerfull and should not be used.
This is what I've been told by a watchmaker. I always follow this advise and have never had any problems.
I bet someone with more experience in the forum can give a better solution.
I demagnetize before working on a movement as well, for all the reasons Bob has pointed out, plus it protects your tools from getting magnetized as well.
I also do it after the watch has been reassembled prior to adjustment\calibrating ... that's my 2 cents worth.
Agreed! It is very essential to demag after cleaning if you are using a watch cleaning machine with a motor :)
Good to know that bit Mark, thank you for pointing it out. Do an ultrasonic qualify for after cleaning demagnetizing? Maybe that's an exception? Please, advise and thank you in advance.
Not entirely sure but I would just make it standard practice to demag after any cleaning cycle no matter what the format :)
Hi,I went on your message and thought I will buy the dimagitizer it worked on one but not on the other two I put it on the time grapher and it still does not time right and cannot get them right still runs to fast, can I ask what I can do next thank you again for your help.Christopher.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
