Cat gut or what was/is used in weight driven clocks?
Endeavor
Hello All;
An old Waterbury Clock Co, weight driven wall clock has landed on my desk. It wasn't working. A quick look underneath the dial revealed the problem; both weights were, or used to be, suspended by fishing wire. Most likely lifting the weights caused the fishing wire to untangle / jump off their drums, wrap around the winding-shafts and jumped off the pulleys in the top of the case. Obviously, by lack of power the mechanism ceased to work and, from what I understood, the clock has been hanging for decades in the owners kitchen as a non-working heirloom.
Her is an internet picture of a similar movement;
There are on either side of the movement wires running up, over two pulleys in the the top of case, down to two weights, situated left and right of the case.
What type of wire is used these days? I think cat-gut was used in the old day, or perhaps still is? A "cat gut" search by CousinsUK drew a blank. Steel cable seems quite rigid, the winding drum diameters on both sides are about ø 10mm.
Can anybody tell me what is used these days and what the name is? Has CousinsUK any of this type of wire?
Any help is highly appreciated ;)
Roland.
Edited by Endeavor
Thanks Mark ;) Once you know the proper name, it is suddenly "everywhere" :)
Any idea what "system" is used to suspend the weights to the gut lines? In this case, next to the fishing wire, fishing equipment, required for hook and sinkers, was used to suspend the weights. I guess the repair was done by somebody who also had fishing skills :biggrin:
@Marc Interestingly enough, one can download a pdf catalog in the last link you have given me;  Meadows & Passmore: www.m-p.co.uk
They do have lots of clock parts and if one scrolls down chapter 1 "driving mechanism" to page 1-13, there is a specific part referring to "American weight clock cords";
5a472a95027e7_ScreenShot2017-12-30at06_48_30.png.65fc88fcd32d37d6990b30339f9a2206.png
It seems that for 30hrs clocks synthetic cords are used.
I wasn't 100% sure about gut-line as this, despite being only 0.65mm thick, once the weights are taken off they may also "un-coil" or "unwind" on the 10mm drums (?). The winding drums don't have guards or guides, so once the wires slack off and starts to "un-coil", they may go "anywhere", also next to the drum around the winding-shaft, like the fishing-wire had done. Normal cord may not have any residual tension in it and may stay nice in place on the drum ....
Unfortunately Meadows & Passmore are expensive with their postage to Denmark, over £10 for a £2.50 order :(  Have to source somewhere else, but the idea is born ..... :)
Edited by Endeavor
The original line would have been a thin type of rope. The two ends to the weights would have had two smallish steel hooks, when tide to the rope would then hook up the weights. Not sure, you can still get the size rope. Try not to use catgut as the stuff today is just a poor synthetic and if you are not careful, it kinks, and tends to unravel and becomes weak. The best type is a steel wire coated in a plastic, as you say the right width is necessary. A tip here when you tie the end on the barrel side heat the plastic and it will mould and seal, careful not to let the flame run up the line as it will burn all the coating off.
 The photo you show is a movement fitted into an ogee case
@oldhippy thank you for your response ;) Yes, I think that I will try to get the braided synthetic cord. The cord, about 1mm in diameter, has to be fed through a hole in the drum. On the other side of the drum sits a small recess for a kind of brass bead. The fish-wire was fed through that bead and the end of the fish-wire had a knot. Once pulled tight, the bead would sit in the drum, preventing the wire to slip through. By the looks of it, those beads seem to be part of the original "mounting-system".
As for the picture and the case; Last night I didn't feel like taking pictures and found on the internet a similar looking/model clock with the same movement. The case of the clock under discussion is made out of a simple wood and painted over.
As for the hooks, I probably order some brass chain-hooks and a stop to be mounted above the weight. The stops should prevent that the weights gets pulled into / onto the wooden pulleys on top of the case.
5a4764d0522af_ScreenShot2017-12-30at11_04_42.png.51eeb4e32502039fc7f3224e4ec0ad64.png
Edited by Endeavor
Okay, great to know; thank you ! ;)
The top of the "S" will most likely also serve as a stop against the top-pulley. See if I can get some of those "S"'s. The 1mm braided wire is however the most important ......
Edited by Endeavor
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
