Hi all. I picked this up cheap and it works fine however it randomly sticks and loses time then starts working again . Any suggestions . Complete strip clean and rebuild ? On a side note I notice the calendar alternates between Arabic and English ( on setup only. In normal use it jumps 2 keeping it in English ) I presumeI need to set it correctly in rebuild d17cb1361a4494c3105aba522b24af67.jpg27159da1762ad0c891f306a4e4975437.jpg
First of all, I'm not sure if this is a fully legit Seiko. I don't think that I've ever seen one with a big JAPAN MADE written on the dial... There are a couple of marriage/franken  Seikos out there but usually the expensive collectible ones.
Yes, you should service the watch and then it will most likely function properly, unless there are inner components that might be damaged...
The day wheel alternates between english and arabic so that you can either set it to display english OR arabic days. That's why it changes "normally" on its own.
Hi. How could I tell
If it’s legit. I will strip
It tonight and upload some more
Pics
You can tell us what the reference model on the caseback says. It'll be 8 numbers and letters (mostly just numbers) split into 2 groups with a dash line in the middle. Something like 7S26-0020.
54 minutes ago, ro63rto said:
It's a fake/repainted dial at the very least. Completely wrong font used on Seiko badge.
Put up a few pics of the movement itself please.
good call!  IF; you can learn how to spot a fake ( or frankenstene [ which may be a good parts watch]),  you will save yourself tons of cash.  vin
e0c914d58c77b7d8b2df21eff9e8523c.jpg7c3a2dcebdabc0b7a4405bdc4ac3ef60.jpg881636b5c33802fec5145aa0fb76bc09.jpg
No idea what I have here
41 minutes ago, Boogi11 said:
Yup, not sure what it’s worth. Cost me £15
With few quids more you can get an honest, genuine Seiko 5.
Topic moved as there is no specif repair question.
  • 2 months later...
Are you sure? I'm watching 2 of these on ebay right now, exact same dials
All fakes from the same faketory. They haven't got right a single detail :startle:
Isn't that the 6119 movement? how can you tell the movements fake?
You mentioned dials, I told you what's wrong with'em - everything.
Since the onset isn't promising, if you want to find what's wrong with the mov.ts, go ahead and buy.
  • jdm locked this topic
This topic is now closed to further replies.
