Just had a look at it on your pages.  Why would anyone wnt a soulless iWatch when there are wonderfull watches like that around.  Hopefully one day I will finally get my hands on one of my Gt x3 grandfathers bits of work (Benjamin Harlow Lane End Staffs) it will be Georgian and definitely older than me at last (:-)).
Baking Bread today. They are going to be Olives and Cheese buns specials. Cheated a bit using the dough making cycle of my bread machine but the baking smell is now permeating the house.
Cheers, Vic
I was supposed to bake some bread this morning but we decided to sweep and wash down the patio to get rid of all the builders' grit and dust after our building work at the back of the house. I'll probably make some tomorrow. I used to knead my own dough but the bread making machine does it just as well.
Bit off the posting now but these are my iBuns - Cheese and olives inside toasted cheese and onion on the top. Smell better than the watch, perfectly visible at every angle, don't need recharging, satisfying and you can put butter on them without causing any damage.  Also when you look at them you can tell the time - time to eat one. :D
  • 7 months later...
Ah! The new Patek competition...at what US$17000+ I believe? I saw and add and the price seemed like a joke! The whole watch is probably one chip they bought for about US$.25 in bulk and is mass produced! This advertising says "you do....things that simply weren't possible before" and that is correct, it makes a lot of money, very fast for Apple! :)
Cheers,
Bob
Does it come with a really small watch band ? I have just thought of somewhere to wear it.
My son in LA was up all night preparing for them to go on sale, He then had to look happy and joyous when the first customers are whooped and high fived into the shop - does not come easy to a geordie lad :D .  However, I admit he has bought one (with staff discount) which I will see in july when he arrives also with numerous goodies I have bought on the Bay in the USA.
Cheers,
Vic
Mark,
How about a spoof video on how to fix an apple watch you can then cut to the tools needed, just one, a muckle great big sledgehammer :crazysmile:
Cheers,
Vic
Mark,
Cheers,
Vic
No problem - get your son to gift me one and I will go to work on it!
:D
  • 6 years later...
OK this is a realy old posting and hopefully no one will read this 🥵 I am obviously a hippocrite as I have an iwatch 6 provided courtesy of my son.  It does provide certain health benefit advice that assist with the various medical conditions I currently host.  However, I will not get used to my watch picking up all my calls and texts and immediately drawing my attention to them as well as the numerous deliveries from Amazon etc.
My activities have been somewhat curtailed recently due to sight problems and other stuff but I have not quite given up on the hobby it just takes much longer to do anything.
Happy new year to all,
Vic
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
