Nice movement made in the 60's featuring the tiny little micro-rotor. This is a Hamilton but I have seen this movement in other makes like Universal and I think Baume & Mercier.It has a 19,800 train.
The problem with this was that the watch was not auto-winding. Turns out there was a wheel in the auto-works placed upside down!
After service it ran very well. After a full wind it too over 45 hours to stop.
Some pictures for your enjoyment...
Click here to view the article
Thanks for the pics Mark.  Love the assembly instructions under the dial.  Now all I need is a watch with assembly istructions on all the parts !
Cheers,
Vic
Cheers,
Vic
Yes - I was worried that the assembly instructions would come off in the cleaner - then what would I do?? Lol :D
I do like that movement, and I'm surprised that Will doesn't have one in his Hamilton collection.
I think that will soon be rectified ;)
Thank you for showing us this beautiful movement Mark, I believe I saw it also in a Longines (maybe not the same exact one but with a little rotor)while browsing ebay! I didn't think much of it but now this is in the wish list!
One problem though, the included instructions are not enough, maybe we should complain to the company? :)
Just spotted one of these in an online auction - might have a punt on it. Start price is just over £100. we'll see...
  • 8 months later...
Hi,
   I read this article earlier and enjoyed it very much and now I am servicing a Heuer caliber 12 with the exact same issue, the auto wind won't work. I looked at the pictures in this article and for the life of me I can't figure out which wheel was upside down unless it was the one under the big red jewel. Anyway I will post some more pictures under my post dealing with the heuer for anyone who hasn't seen that version movement with a chronograph module attached.
Hi,
   Thanks for extra link. The one comment on the gritty feel while hand winding was really helpful. I noticed that the first thing before I did much of anything with the Heuer. I have been trying to figure it out ever since. I think my winding issue is mostly just grime. While the movement isn't as dirty as some there are some spots on the winding wheels. You are also right in your comment about that movement holding a lot of power. I got the one I'm working on ticking Sunday and it's still going today. I put it away when I found I needed a set lever and screw. I ordered them but was told today that the set lever would be on back order. After I heard that I went back and managed to grab the nub of the set lever screw with tweezers and back it all the way out. I don't understand why it was so easy since the screw rung off earlier unless the screw was badly worn already. Anyway I do want to thank you for your suggestion and videos.
Charles K
  • 6 months later...
Hi Mark,
I just got a Hamilton thin-o-matic Masterpiece auto from the 60's but I can't see where to open it. The back is engraved for someone's 25 years of service. I suppose the back can be removed -- because of the engraving -- but I don't see where. Any suggestions?
Thank you in advance!
Cheers,
Bob
Yeah, right, I forgot! :)
I have a feeling it is a split stem with a Buren movement (small rotor) and front loader...still, it is not mine and I don't want to bust it! Have anyone worked on one of these before?
Cheers,
Bob
I have one of these myself Bob, but haven't serviced it yet. I've just had a look at it and I'm pretty sure it is a split stem front loader.
I suspected the same, I think I won't tinker with it yet, the watch not being mine. Pity because it is in serious need of maintenance. I don't think I'm ready for this type of case in other people's watches! :)
that is a beautiful dial. it looks like the day it came off the watchmakers desk. and blued screws on the movement. that's a nice touch.
i've looked at a few of these hamilton micro-rotors on fleabay. i like them. it's hard to believe that a rotor of that size can wind those wheels.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
