Waltham A11 8 Day aircraft clock
Tmuir
You know how it is, its late at night, you have had a couple of whiskeys you are browsing ebay and you see something, you place an impulse bid and wake up in the morning to find you have won it.....
ACtually quite pleased, its a bit rough but price was good, hopefully when it arrives it will be in a state worth restoring.
I like military clocks, I've got a couple of Russian MIG clocks, a Russian Tank Clock, an American Seth Thomas Navy Deck clock and now a Waltham aircraft clock.
Just need to get myself some British ones now....
It will be a couple of weeks before it arrives, but there are a couple of taster photos of it on ebay.
No idea of its exact age yet other than it cant be later than the 1950s, but if I am lucky will be of WWII vintage
https://www.ebay.com.au/itm/VINTAGE-WALTHAM-8-DAY-A-11-MILITARY-AIRCRAFT-AVIATION-CLOCK-/382333164905?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=oZxjZV%2BqZEhnkGjEDMhqfs0Js7M%3D&orig_cvip=true&rt=nc
good show.  had any ships clocks apart?  Vinn
I just can't help myself.
Was trawling ebay again and found an Elgin Pioneer aircraft clock for sale in Australia.
I do know this model of clock was used in some Australian made aircraft and what was very interesting about this clock is it has scratched on the back of it A20-343, this is the service number for a Wirraway Aircraft that was made during the war in Australia.
Only 15 Wirraway aircraft still survive out of the 755 built.
I've not managed to confirm that this model of clocks were used on Wirraways yet, but if so its very exciting.
Anyhow enjoy a couple of photos of it, it is not working and judging by the rust on the screws it could be in a bad state, but we will see.
  • 7 months later...
I posted in the clock forum but I'm excited I found this thread again as this is what led me to the site to begin with!
My clock looks very similar to your aircraft clock. Do you know if this one is also an aircraft clock? Thanks in advance for your help!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
