Elgin Pioneer 8 Day Aircraft Clock
Tmuir
3 minutes ago, Tmuir said:
Sorry for the late reply, been busy lately and not online here.
That case is slightly different to mine, but should come out the same way.
Remove the crystal from the front by removing the split ring which it looks like you have already done.
Don't worry about the winding knob you don't need to touch it, it says in the case.
You don't need to remove the large blanking screw with ADJ next to it, that is to just give you access to he regulator when it is in the case.
You need to remove the smaller screws you can see on the back, mine only has 2, but yours looks to have 3.
Certainly the one to the left of the ADJ screw cover and the one opposite that, but it looks like yours has a third screw.
Once you have removed these screws the movement will come out the front, you may need to angle the top (12 o'clock) part of the dial first so the winder disengages for the movement.
Thanks Tmuir, I'll have to remember that in case any others need help. It can be difficult trying to help with just photos of a clock when you haven't repaired one.
It's pretty common that the winder stays in the case with these aircraft clocks. The photo attached shows two movements, a Waltham case on the left and an Elgin Pioneer on the right with the movements removed showing how the winder engages with the movement.
5 hours ago, oldhippy said:
So I see. Are the movements 8 day duration or just 30 hour?
They are 8 day movements and of reasonable quality because if they didn't work correctly a pilot run out of fuel before they returned to base.
For those interested the best reference book for US Military timepieces is 'Military Timepieces' by Martin E Whitney whilst for Military timepieces by just about everyone else the two best books are British Military Timepieces by Konrad Knirim and and Military Timepieces again by Konrad Knirim for German and their allies timepieces.
Although Konrad's books are excellent they are expensive and you have almost no chance of finding a secondhand set.
  • 2 years later...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
