I would like to buy a bench and could do with some input please. I found this one on ebay
http://www.ebay.co.uk/itm/WATCH-MAKER-BENCH-3-5ft-BY-2ft-HAND-MADE-NEW-STRONG-BENCH-/281393251977?pt=UK_Crafts_JewelleryMaking_GL&hash=item4184584689
What do you reckon, do you think it looks suitable?
I'd prefer this one but can't justify that kind of money at the moment
https://www.cousinsuk.com/product/jewellers-watchmakers-benches
Or is there anything else anyone can recommend please, need something with more height then the desk I'm currently struggling with.
Thanks
Ray
If I was going to get one - which I'm not - I would make one from a steel strut system, like the old Meccano girders but bigger. Once a basic framework is made to suit your requirements, then a top can be fitted, and plastic trays/boxes used as storage fitted into spaced struts. It might not be pretty, but it might be a darned sight cheaper...
Musicians use all sorts of metal racking systems for amps and other sound equipment, so the materials are available.
True, it is pricey for what it is and the materials it's made out of. Need to do something tho, I'm using my home office desk at the moment, and shifting the computer and everything off it to use it is a bit of a phaff, it's far too low as well so not good for the neck and back.
I'll look into your suggestion, cheers.
I've seen a great one assembled from parts at Ikea. Not sure on cost but it looks great.
These are the parts he listed.
100% IKEA parts used:
2 x EKBY Alex, 2 x ALEX, 3 x EKBY TÖRE, 2 x CAPITA 16 cm, 1 x CAPITA 10 cm, 1 x LINNMON Grau
Thanks
Ray
Hi Ray,
It looks like the ebay one would be simple to make for a fraction of the cost & you could buy some nice tools with the money you'd save, especially as it comes flat pack anyway !       :)
Think I'm going to go for the ikea option, don't think I'll bother with the drawers/shelf mounted on the back of the desk top so could put it together for around £200 depending on the top I choose. It stands around 100cm high so hopefully that'll be ideal. I'm taking a week off work at the start of next month so I'll get it then, there's no way I'm going to ikea on a weekend, tried that once 10 years ago and vowed never to go through that again!
  • 4 weeks later...
Great job Ray, looks wonderful. Was it too difficult? I will eventually get one myself. Have you considered adding a railing around it? It will stop most flyers when you work on watches.
Thanks guys, wasn't much trouble getting it together and I'm really happy with it. Only tricky bit is getting the bench top on the drawers, you have to fit it to the top drawer panel before assembling the drawers because it would be impossible to get your hand in if you assembled the unit first, oh and the legs at the back under the bench top are way too short so you need a lot of washers to get the height correct. Apart from that pretty straight forward and seems really sturdy. Regarding the railing, at the moment I have made a guard out of wood which I can place on the desk to stop flyers but will have to think of a more permanent solution to the problem.
Going to buy a decent lamp next which should fit nicely at the back of the bench top.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
