Which balance staff do I need for this Hanhart Anker 11 Stopwatch please
Similar Content
The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
For me the text looks too aligned and with no obvious way to grip as a screw back.
