I think 1 3 and 5 are for holding and screwing in timing screws on a balance. 2 and four I haven't come across those ends before.
Edited by oldhippy
I thought 4 might be for pulling cannon pinions???
4 looks like the staking stump used for removing rollers from a 2 arm balance wheel.  Maybe it's to hold a balance securely?
Perhaps! It does have a Grove on inside as well
On 2/18/2018 at 11:07 AM, jdrichard said:
Here is shot of the end of one of the tools.fa24394dd5f05bbb691256b4a5b805ca.jpgIt has a gap and a hole on the other side. Wonder what this is for??90d485454a8df6f6701bfdb1a912d636.jpg
I believe it may be a vice for holding seconds hands for broaching. The hand pipe would slide into the slot, and the hole would line up with the pipe to insert your broach.
Tool #4 is for holding pallet forks :)
Tool #4 is for holding pallet forks [emoji4]
Best guesses so far. Might also be correct
