Thank you all, Now I just have to wait for the watch to be delivered. I will take pictures then.
I beleive Its a Longines, couple of variants to this calib were made, one with flat and several with overcoil H/S, overcoils were furthure modified, thus new designations. TG reveals it's worth, when serviced.
What other parts have you got apart from what's in these photos?
Longines have a service where you can send the serial number and they will tell you the date and name of the agent the watch was sent to. I'm not sure about the case, but I would expect "Longines" on the dial
By nickelsilver · Posted
The modern ones are graduated in 0.01mm on the know, this one not. You learn quickly how much to turn by feel and can hit the thickness wanted- and yes, I use a vertical mic to check the thickness often.
