I came across these pictures of what turned out to be my trickiest job.........ever!
The watch is a Goliath pocket watch and the problems were:-
Staff broken at one end.
Hairspring distorted and contaminated with super glue.
Being a Goliath, I thought the staff might just be large enough to allow me to make a repair by re-pivoting, after all the shaft was 1mm diameter. So decision made, I dug out my watchmakers lathe, some pivot steel and a 0.5mm carbide drill. It was more than fiddly to make, but I did succeed on my second attempt.
The first thing I did was to strip down the balance wheel and leave the hairspring soaking in acetone to dissolve the superglue that was binding the spring. I then mounted the wheel complete with staff still attached into the lathe and bored out the end of the shaft. It was a bit like mating hedgehogs! That done I turned down a piece of hard pivot steel using a carbide tool before polishing and fitting to the jewel. I decided to turn the steel when in the hard state to save me the bother of softening it and then having to harden and temper it.
The new pinion was then fitted to the staff. To ensure correct alignment, the staff was held in the headstock of the lathe and the new pinion in the tail stock. I applied a tiny drop of Loctite 386 high strength retaining compound to the hole in the staff then slid the pinion into the hole by sliding the tail stock along the lathe bed. When cured the pinion was rock solid and in perfect alignment.
Now I turned my at tensions to the hairspring. The acetone had done the trick, the spring was now perfectly clean. I pushed and pulled, prodded and twisted and eventually managed to get the spring back in shape.
I now fitted the spring to the staff in its original position and fitted the assembly to the balance cock. This assembly was then fitted back into the movement, and started to tick away quite nicely. After minor adjustment, it is holding about eight seconds a day.
Here are few pictures, the last picture shows the watch running, hence the blurred balance wheel.
I'm in the wrong forum! I thought we were bragging about striping and cleaning and putting back a basic simple watch...
...chronographs, moon phase, and now staff rebuilding... oh come on!  I QUIT!
B
p.s. I'll just stick to reading and asking stupid questions!
B
No you won't - this forum is for all levels.
I demand that you contribute whatever you like (in the context of Horology) :D
Well done George - cracking job mate!
Definitely no bragging Bogdan, it's just a wee story of how I got around a problem. I do what I do and just hope I can help someone in the process. :-)
Edited by Geo
I wasn't saying you were bragging, Geo, sorry for misunderstanding. I was referring to me - "I thought we were bragging about striping and cleaning and putting back a basic simple watch". (a little self irony)
We are learning to fish, and you are hunting whales.
And of course I was kidding. Of course I will spam you with obvious beginner stuff...
Edited by matabog
I think anybody who can strip and put back together a watch, even if mistakes are made, no matter what level they are on deserves a pat on the back - its not an easy job :)
I would like to also work on lathes and broaches and washing machines, but I am still talking about a hobby with limited time (10pm - 3am), funds and a very, very small WAF (WAF is the international unit measure for Wife Acceptance Factor)
Very impressive and inspiring. Thanks for sharing. One thing I like about this hobby is that there are so many levels to it. Some may just like to mod watches with new hands and dials, some want to learn to service their own watches and some to make and repair parts. There's a lot of enjoyment to be had at every level.
I second Don, exactly my thoughts, and great job there Geo! If I'm not mistaken you just fixed a Breget overcoil! Way to go!
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
