The 4 free watches I got this morning are little crackers - far better than I expected them to be, with simple but well-made movements and fairly rugged cases. All keeping good time so far and with clean movements. The Chinese Chumei and the Indian HMT Suraf have screw-on cases and were simple for me to uncover, photograph and re-cover. The other two Indian HMTs have parashock cases with snap-on backs. Both were stiff to prise off. One - the Kohinoor - went back OK with the case press, but the other snap-on back will just NOT go on, even with the case press screwed very tightly. I've checked it for position, notches, etc., and can't see a problem. But will it click in? No it won't.
Any advice?
On a serious note, it surely just needs a lot of pressure making sure that it is applied to the outer borders of the case.
Any advice?
Hi Will,
I have the same problem at the moment (posted in Armani chronograph) and I actually broke the glass trying !, I think it might be because my press has nylon dies the nylon is flexing and absorbing some of the pressure whereas aluminium dies would not do this, I'm going to try another press or as Geo says
''A big hammer'' :pulling-hair-out:
I use nylon dies and as I said before, the dice have to be selected properly so the pressures apply only on the spots needed, otherwise the crystal breakes or the back shifts and may damage the stem or any other part. It is possible that being nylon they are much more picky than the alluminum ones.
My press also has nylon dies.
Is it a hand held press or one of those that look like a drill press?
I have a hand held and find I need to put it on a solid table to lean on it. It too has nylon dies.
It's a drill press style - on a stand with a screw down press. The watch goes face down on to a die and a die goes on the case back, with the whole lot being compressed by the screw mechanism.
Will,
I have had a few of these bugg**rs I think the back distorts when opened. I found that a smear of silicon grease on its rim and a machine press does the trick. I was told once by a watch repairer that putting the back in a freezer for a while helps as it very slightly shrinks the metal. I have never tried this method but the theory sounds good.
Edited by clockboy
I was about to suggest that a bigger hammer was not necessarily the right way to go and was about to suggest a smidgen of grease where the back snaps on but was beaten by other members. Let us know if you get it back on Will.
Thanks for the grease heads-up, folks - I'll give it a go!
Im sure I need not say this but make sure your lower die clears the glass.
Is your press a lever type or a screw type? I find the screw type to be far more useful for these annoying tight ones as I feel more in control. But keep making adjustments to the position and you should get to the sweet spot.
Cheers Mark - yes, I've been very careful to avoid pressing the glass, and made several adjustments to the upper die position.
This morning, I even inserted a 50p piece between the screw of the press and the top of the upper die - because the pressure was pushing the screw into the plastic upper die rather than exerting its full pressure on the case back. Result? The screw just bored into the 50p piece!
So, no more on this until I get the Seiko silicon grease.
I think I would be wary of this incase condensation forms on the inside of the watch !
Alternatively, heating the whole watch under a torch and leaving the back at room temperature will avoid humidity! :)
On a more serious note, I started to think: Maybe the gasket is being pinched while pressing the back on. Did you check the gasket Will? It may be hard to spot in some watches thou.
if you post it to me I'll put it on for you, although with the cost of postage its less than an ideal way!
That's a very kind offer, Lee, and I may well take it up. I'm seeing a watch repair friend of mine next Tuesday down near Southampton - one of my regular visits where we drink coffee and talk watches for a morning - and I have various little projects for him. I believe he has some silicon grease so I'll take it over with me and we'll see what he can do as he also has various case presses. If he can't succeed, I'll gladly contact you.
Success with the case back this morning. I went over to see my watch repair buddy in Bursledon and - between us - we managed to get one side of the case back firmly in, with one side still proud. I spotted a small bench vice with 4" jaws attached to the side of his workbench and suggested that, with suitable, padding, that might do the trick.
So we put the right plastic dies in place, added some extra dies for safety and, working our way around the rim, used the vice to ease case and back closer together. Finally - with a gunshot sound - the case snapped together! It's never coming off again while I have it!
And all the while the watch was ticking away merrily... :woohoo-jumping-smiley-emoticon:
Yeah! Way to go Will! Did you check the inscription on the reverse back of the watch, inside it, before closing?...Just kidding! :)
:phew:
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
