Just finished working on this 1894 Elgin 6S, Grade 117, 7 jewel watch, and it seems to be running ok. Hope you enjoy the pics and my little newbie adventure [emoji4]
9f78421f4e1a62aa0928f31b958d32a7.jpg&key=c817c1c1d884def4f2baa1d35af8fe4939a5b33cd980d810878e8445b2d195e0
Got the whole watch on eBay, minus crystal and not running well. The gold filled Keystone "cyclone" case is kind of worn down but still looks ok to me.
d99adc98bef4a8bdfa76f12b4874d1c6.jpg&key=558303145c80344ad6489632c2bd52d3045cd77912589b40ed6c8adb55d042c9
After cleaning, the amplitude was poor, like 180° poor. I pulled the mainspring and it was about as set as they come. A NOS replacement went in.
And the amplitude was still terrible! Then the impulse jewel fell out. Until I get my warmer tool, I swapped a balance from a compatible watch just to see if it would run worth a darn.
487fba78753346a234ff1c1d1b4e24ac.jpg&key=45f000f2b43e01780fb079c96cb2e5f5924471b6495fabf6c25b43fa8d998a8a
The guard pin needed adjusting and it took me forever to get the beat error down to a crummy 2ms. And still poor amplitude.
I remembered seeing divots on the cap jewels so I swapped those. And despite the fairly loose pivot holes, she finally started running right, plenty of amplitude. Whew.
Now, it does have a massively bad rate discrepancy between pendant left vs. right. I will have to address that at some point.
I recased it (the two had been separated for almost a year now) after finding the stem bits.
af92780a5320d8df069c56d4e20bc96b.jpg&key=7d8eb69c693f381c819487ba4eac520af3d1365bd47dd87ad4c9f04ae88ddcbf
Cleaned up a couple hands and re-blued them and good to go. Now I just need to find a crystal.
eb1569ea889470e61fcec58c4bf1ba61.jpg&key=e34880de5ac42177ec480e28280db4a73a24d61b078a4a8698c3a6debf4157ca
Sent from my Pixel 2 XL using Tapatalk
Well... Crap. I think the mainspring came off the arbor again. I have the worst time getting mainsprings shaped right to fit on arbors.
Was able to address the mainspring issue.
I have had zero luck with crystals. Broken two trying to install. I need to rethink my technique.
A plastic crystal is inbound in the meantime so I at least can use the watch.
I find that old mainsprings, especially the blue ones, lose their memory a bit with age. Hmmm...sounds familiar. If you don't already have one, a set of mainspring pliers might help you get that inner coil shaped better. It's sort of a round-nosed plier with stepped sizing for a couple of different sizes of inner coil bends.
Crystal replacement is a specialty in itself, especially the thin Geneva style for hunter cases. I'm still not great at crystal work myself. Hang in there. Nice little Elgin, BTW. Cheers.
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
