Thank you Guido, here is a translation for the rest of us :)
"Actually, they don't. [answer to Blake question]. Professional watchmakers have room for experimentation. There are norms that are conducive to precise results. However, in the present table, the properties of automotive lubricants are shown only for reference and their properties. Lubricants have certain properties that makes them appropriate to fit certain conditions such as temperature, work conditions, etc. To know the properties of lubricants -- like viscosity, measured in cst (centistokes) - allow us understand better the art of watch lubrication. Personally, I've experimented with synthetic motor oils in Swiss watches. Those are my own watches that I use for experimentation. When I actually work I recognize that lubricants like Moebius 8000 are indicated in most critical parts in Swiss watches. For example, the escape mechanism, pallet fork, pivots.
Here is a graph of a watch that has been lubricated with synthetic motor oil:  .... "
Cheers,
Bob
Thanks for the help with the translation but the truth is that I write in Spanish and use google translator subsequently rectified.
Thanks Bob. Something bad happened to my answer I believed was translated.
Thank you for your words Super WRT Addict, too.
To Rob. Thank you very much for the table already copied and will be in my files and references of lubricants in watchmaking.
Guido
A belated warm welcome from Scotland Guido, and many thanks for posting the valuable information on oils.
Welcome Guido. From the little knowledge I have about various oils (yes I know a little knowledge is a dangerous thing) and disregarding viscosities - watch oil is designed to stay in place, car oil is designed to flow all over the place and has slip additives, motorcycle oil is basically the same as car oil but without the slip additives as this would cause the (wet) clutch to slip.
You're right WRT Addict, do not mean that we should abandon the canons established lubrication.
But understanding aspects of lubrication in vehicles helps with understanding the ultimate goal of lubricants: reduce contact metal metal, plastic or metal in a mechanism, to prevent wear and make efficient mechanisms.
Abraham-Louis Breguet a famous watchmaker once said: "Give me the perfect oil and I will give you the perfect watch." Mechanical watches do not stop being that, machines that need a suitable lubricant.
In the document I have given a way to Essay, we refer to the properties of the best known in watchmaking lubricants. Our goal is to have a better perspective of the role the various types of oils available in the watch industry.
For an old watch for your own use, what about model railway oil. The smallest gauges; N & Z Gauge are very fine mechanisms.
If you're looking for more detailed information on Mobius oils they could be found at the link below.
Starting on page 18 is a section labeled "Cleaning, Lubrication, Surface Treatment"  This is a rather interesting section of the PDF explaining the importance of cleaning properly. Then reading farther on you'll come to a paragraph starting off with the interesting question of    "Why do watches require special oils?"  Where it explains the difference between lubricating a watch and lubricating some other mechanical devices.
http://www.m-p.co.uk/muk/acrobat/hse/moebius-hs-sheets/moebius-specsbook.pdf
Welcome to the forum John, and thank you for posting the information on oils. It's always good to hear from a new member, and I look forward to hearing about you exploits in horology, be it professional or hobby. :)
Dear John, thank you very much for sharing this valuable document forum. As people who admire mechanical watches, these aspects of the art clocks interest us. We will keep pdf document. And started reading the material.
Yours Truly.
Guido
Hi Guido. I've watched the video you posted a couple of times and to say the least it intrigues me. Is this your own video?
 Hi Geo, thanks for your comments and see my video. Yes indeed I did, and I made all the procedures shown here. If you have any questions about something I can gladly try to give you more information.
Yours Faithfully,
Guido
Question: the manual calls for Moebius A and Seiko watch oil S-6.  It does not call for any grease.  In most of the posts I see recommendations for Moebius 9010, Moebius D5, etc...  Can someone give me recommended equivalents that I'm likely to find in these local shops for both the Moebius A and the S-6?
For your lubrication question you have a minor terminology problem that comes up quite a bit. Moebius Lubricants sometimes go by other names such as SYNT-A-LUBE which gets shortened to Moebius A Which is really 9010. Then as you're looking for S-6 I assume you're looking at a Seiko sheet and that's their general-purpose grease.
John
Hi all,
I am looking to buy a good set of oils to service my watches, but since I am not a professional watchmaker, for me it is just a hobby for the moment, I have no idea what to buy first and foremost. I found on eBay this auction / buy-it-now offer: 400240980909
Is this a good starting point? Until now I have used a generic watch oil I had found in a flea market sale, but the results are not so good, to be honest.
Any advice is appreciated.
Thanks.
It doesn't look bad and you're buying a brand. Shipping is expensive though...
I buy my oils from this offer : 151144554717
Haven't bought anything from this bayer . Nice collection of moebius oil and greases . Too bad my french is worse than my english
Hi George,
welcome to the forum. I've purchased many items from Elisabeth and all the oils are genuine top quality. I've also purchase from j Borel hee in the U.S.  and Elisabeth is cheaper even with shipping from France--as long as you can order so that she ships in one shot.
JC
Hi George,
Your link appears to refer to a bundle...and it is not what I would buy right off. I'd rather hand pick what I need since oils expire and if you don't use them you will lose the money. All that said, I would get D5, 9010 and some other essentials for the barrel and pallets...there are options, the bundle doesn't have them. Just an opinion though.
Cheers,
Bob
This topic is now closed to further replies.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
