Rado movement replacement
Hi,
I have an old Rado Diastar Quartz watch that belonged to my grandpa, but it doesn't work anymore. My dad tried having it repaired once and had a terrible experience with Rado. In the end they flat out said they couldn't repair it and gave it back.  The design of the watch seems common to a number of old Rado watches, both automatic and quartz. I can't seem to find a second hand quartz movement but found automatic movements for the same design. Would it be possible to replace the quartz movement with and automatic? I'll add some pictures of my quartz movement and the automatic(ETA2789).
Thanks in advance for any advice!
The case may look the same, but I doubt an automatic movement would fit into a case made for a quartz--it wouldn't be deep enough to accommodate the thickness of the movement. The ETA 2789 is 5.9mm in height. Can you remove the quartz to measure? While you're at it, it would be worth looking closely for any markings or identifiers for the quartz to see if another brand used the same.
J
  • Similar Content
    • I'm new to watchmaking. I have an omega seamaster polaris that I'm  trying to repair. The setting lever tab was broken off.
    • I'd considered contacting a broken but have no idea if Mark did want to sell the site what it would be worth.
    • Is it water moisture ?  If so and you have good sunshine where you are, just put the watch under direct sun light ( Dial facing sun )  a few hours, sun light dries the moisture. Depending on the amount of moisture, lubricants in movement might have been ruined. No other source of heat is safe.
    • If Mark’s lost interest in this great site, then hey — it is what it is. We all move on from things. I’ve had hobbies I was super into for years, only to drift away from them when life took me in another direction. That’s totally normal. The thing is, this isn’t just about Mark — it’s about a whole lot more, and a whole lot of people. I actually think WRT might have some decent commercial value. Take WatchUSeek.com, for example — it started off in a similar way and eventually got sold to someone who saw the potential to grow it and make money from it, mostly through ads from watch brands. Maybe I’m being overly optimistic here, since people who collect watches and those who repair them are pretty different groups — and not exactly equal in numbers — but still, I’d be curious to know if Mark’s ever gotten any offers to sell WRT. Personally, I wouldn’t mind paying a small fee to keep the site going. Maybe there could be a setup where paying members can post, and everyone else can still read but has to see ads and can’t opt out. Watch repair is probably one of the tiniest niches out there — but since the site’s available worldwide and we’ve got tools like AI now, it’s super easy to talk to anyone in pretty much any language. Case in point: this whole post was written in Swedish and then polished and translated by ChatGPT. There are around 8 billion people on the planet, and if even one in 200,000 shares our interest, that’s still a potential audience of 40,000 folks globally. Maybe a quarter of them would be open to paying a little something and using English to connect. Who knows? I’m just throwing ideas out there — mostly to see if anything sparks some discussion. What do you all think? Would you be willing to chip in a little to keep WRT alive if it came to that? Or maybe you have other ideas?
    • Looks like there a big silver ring around the outside that may need to be removed first but there's enough of a lip showing above that to try and get some purchase on.
