Has anyone welded a watch stem to make it longer? I'm referring to the case where there is not enough thread left for screwing in an extender. I wonder if there is a way to weld the extender to secure it to the stem. Thank you in advance for procedures, advise and/or tools needed.
I have not welded a stem, but I have silver soldered one that had snapped off right at the bottom. I had to do this because I could no find a replacement.
It's pretty fiddly and I did have to make a fixture to hold the parts in correct alignment. Also yo will need a watchmakers lathe to turn off the excess and make a nice finish.
Thanks Geo, much appreciated.
How do you silver solder? Do you use a soldering iron?
I've seen acetylene torches for jewelers, -- and also something that looks like a crème brule torch -- they seem very small but mimicking the real thing. I thought some of those might have to be used because of the type of metal. But then, I don't know much about welding, soldering or anything related other than a bunch of theory learned when I was in school -- ancient stuff -- and the regular tin solder for electrical components and such...not too involved, not even electronic components/circuits. I believe, as far as soldering and such is concerned, my clock stopped in the '70s!!
Hi Bob.
Using silver solder is similar to brazing, but uses a lot less heat. You will need a micro torch, silver solder and flux. When silver soldering I wear clear goggles rather than green to prevent me overheating the work.
1) First make a fixture or use small clamps to keep the parts in alignment, but also ensure that they hold the work in such a way that they don't create a massive heat sink.
2) Align the parts carefully and secure tightly.
3) Apply some flux where the parts are to be joined.
4) Heat parts to dull cherry red.
5) Using a very thin piece of silver solder, touch the joint. The solder should ideally melt from the contained within the work, but due to its size may require just the slightest heat from the torch at this point.
6) Allow to cool and finish off as required.
If you have not done any brazing or silver soldering before, I would suggest taking the parts to a competent jeweller to have done.
The only solder I've worked with has been that for electrical joints, which seems relatively soft. Presumably silver solder is much tougher if it can be used for such things as watch bars, winding stems, etc.?
Yes Will, it is extremely hard compared with the solder you are familiar with. Jewellers use it frequently, and high tensile steel racing push bike frames are used to be held together with it.
Great instructions Geo, thank you, really appreciated. I will try to do it myself...there is always a first time! I first have to order the materials which might take a couple of weeks. Thanks again!
Bob
Make sure you practice on a few test pieces first!
If you have access to a watchmakers lathe, it's a good idea to square off the broken end of the stem without the thread, but remove only the least amount of material possible to get a square surface.
Now drill a small hole about 1 - 2mm deep in the end you have just machined. Get another stem with the same thread as the broken one and cut off the threaded section. Turn the end of this down to the same diameter of the hole that you drilled in the original part.
These two parts should slip together and help keep alignment when you clamp the parts for silver soldering.
I wish you the best of luck!
Thanks Geo, I'll do it that way. Gosh! I'm very impatient now to start. Hope the materials won't take too long to arrive. I'll be ordering in a few minutes.
Hi Bob,
You also need to find out why it snapped in the first place..
Rust?...make sure surface is free of any rust before soldering.
Hard to wind/set? ... if you don't solve thisthen chances it may happen again..
HTH
Anil
been hiding...!
but really, my work does not allow me as much time for my hobby as I would like.. I know its unbelievable in this day and age but I travel fequently (internationally) and my internet access is dependant on the hotel ;-(. Data plans which work in several countries are too expensive and potentially very expensive.
I work as a loadmaster for cargo aircraft, watches fill the time between contracts!
Anil
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
