I successfully (mostly) finished cleaning, oiling and reassembling my first mechanical watch yesterday. I bought a beat up old Caravelle and three movements worth of spare parts. Unfortunately, I dropped the one good balance out of four and mangled the hairspring, so I had to use a backup. The watch sets and runs, but doesn't run well. Also, I switched the dial from the original to one I liked better without thinking to check that it would fit the case - it didn't. But I got it all back together, so I'm considering this a victory.
Before:
During:
After:
If you're observant, you'll notice that the watch changed from 7 to 17 jewels somewhere in the process. You'll also notice that I had a little trouble with the concept of reverse threaded screws. :growl:
these are all things you have to learn...usually the hard way like I did! If you are like me and never had formal training, your mistakes are burned into your brain and you never forget what you did wrong to cause them! I'm not saying they will not happen again, but usually not for the same reason....
Hang in there! it's so gratifiing when you get through an overhaul and the watch is running beautifully!
FYI-Also, you'll notice the screws with the reverse threads have 3 lines on the screw heads, This is usually a dead giveaway that they are infact reverse threads...
Watches are a whole different world,  most other things are made with parts you can see and pick up with your fingers,  not watches.  Well done,  your next one should go better.
Well done - I'm on the same track but I've lost a **BLEEP** screw and I don't have any spares.
The reverse thread screw on the crown wheel got me too.
That's where Marks's videos come in handy - this reverse thread is mentioned in them!
Yes, yes. But where's the fun in following the instructions? :)
Thanks for all the positive comments. I really love this forum. :D
DJW, you're spot on about making mistakes. Each one taught me something. It took me forever to figure out why the stem couldn't be pulled to the setting mode and why the train was locked up. Turns out when you use a ratchet wheel screw on the crown wheel, it doesn't work so well. I'll forever remember the three slotted screw thing too. Most of the setbacks were very enjoyable because I felt I was gaining experience.
Thanks Bob. I ended mashed the different movement parts together and ended up using the trail wheel bridge from a 17 jewel version. I'm not sure if I've got all 17, but the bridge says 17 jewels.
I've already got my next victim, a vintage Lucerne that is currently running slow. I'm looking forward to having the time to tear it apart and apply whatever I've learned from the first watch to it. When I get more confident, I'm going to have a go at a Stowa I bought 5 years ago and have been dying to get fixed.
I've got a used L&R PC3 ultrasonic cleaner. I used Zenith Hi-Tech cleaning solution and Zenith Hi-Solv for the rinse. I couldn't find much info on the Zenith products as opposed to the L&R solutions, but I chose the Zenith because they are advertised as low odor. So far I'm very happy with it.
I'm a little ashamed to say that I didn't read the warnings on the container, but I assume there is some risk of ignition, especially with the rinse, since it evaporates very quickly. The smell was not bad at all for the cleaner and rinse, but I also bought some hairspring cleaner from Zenith and that stuff smells pretty potent.
Hi Don,
Re the 7 to 17 jewels things...?
Are you going by the sloppy stamping on the train bridge? I think that its a legit 17 jewels as the 'seventeen' would have been there from the beginning... just a bit of carelessness.
Anil
Hi Anil,
I had parts from three movements. The one I started with was a 7 jewel version. I ended up using the main plate and train wheel bridge from one of the others that was a 17 jewel version. In the "before" picture, the train wheel bridge bearings are not jeweled.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
