I wondered if anyone had any inside tips on how to get in on the cheap? If you go with a friend it is the price of a used Omega! Welcome to Switzerland I guess.
If you are a school kid, or student, in a party of 10 or more, you get in for 10chf. Good to see that!
I went to Baselworld 2018, for an afternoon. In the end it cost me 90 Swiss Francs, including 30chf parking (Park and ride).
I'm not interested in buying a new watch, I just wanted to get a feel for what the show was like. The stones and gems section was interesting. Masses of rubies, emeralds, sapphires, some really big ones! There was a section promoting components and services from Hong Kong, quite a lot of exhibitors from the east.
Beco Technic had a small stand, and I could try various tools. It would have been worth taking a scrap movement to prod and poke. There are some really sophisticated looking tools, a decent microscope for 1000chf, some micro welding equipment too.
It was also nice to speak to owners/makers from the various small watchmaking firms.
ETA were there, but only the quartz watch marketing department. Miyota had a good presence, with a new range of mechanical movements on show. Their low end mechanical movements were pleasing to the eye given the prices. Citizen had a great stand, with a display about their 1 second a year quartz movement, ecodrive, etc. The stand featured a spectacular display of 98,000 watch movements, backlit, individually dangling on strings.
The most interesting for me was to talk to the owners/founders of small watch and clock firms, German and Swiss in particular. I also wanted to look at some Patek Phillipe enamel work, and was interested to see some enamel over guilloche, with a bit more enamel work than I expected inside the stand. There were also some sofa's and I had the chance to sit down, relax, and look through a copy of the authorised history of Patek book.
I gave Omega and Rolex a cursory glance, as they are well represented in Jewelers all over Switzerland. I asked Rolex for a catalog on the way out, and got given royal treatment, including a hard bound book with a separate price list, by one of the stunning young receptionists on the desk.
All in all, it was fun, and worth the entry fee. Well worth it if you are in Switzerland anyway. However, there are regular watch repairer/watch fair type meetings in Switzerland, tours of the watch valley etc, and I am hoping to explore those at some point. As a watch repairer, if you were booking a trip to explore Switzerland, I think those would be first port of call.
There is a show in Geneva which is far more interesting for those of you into repair / manufacture, it's called EPCHJ Geneva and it's on in June. Baselworld used to have a basement (a very large one) with machines and parts suppliers, but they haven't had it for a few years and these companies are now largely at EPCHJ. My observations of Basel this year was that it is predominantly for retailers & distributors, most of the stands are entry by invite, so unless you are a trade customer then most of the show is inaccessible.
    • I’ve watched every video I can find on YouTube. Some of the info in contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
    • This eBay listing seems to verify that the watch disassembles as I suggested : here. The display caseback is held by the section that pushes out of the outermost rear bezel.  The movement seems to be a Ronda 1113. Best Regards, Mark
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
