Hello.
I "rescued" this huge pocket watch wich is now called GOLIATH, because of its size, from a (troglodyte) seller. He scratched the case trying to open the mechanism lid.
I should start with the very few information I collected from many places, including of course watchmakers and jewellers estimations.
-Size: 36s (60.11mm). The biggest one.
-Case: 70mm(With out crown).
-Case Material: Steel (No Stainless). Gunmetal finish.
-Movement: Cylinder Escapement. Which means it might be prior to 20th Century.
- Dial type: Looks like silver/ gold plated brass with enameled arabic numbers. Perhaps the entire plate is made of silver with gilds.
-It might be made in France. The mechanism lid has a phrase in french (ACIER GARANTI)
According to the above mentioned, the two main questions are:
-WHO MADE THIS POCKET WATCH?
-WHEN?(Estimated year of manufacture)
This particular piece is working, but needs a full service. My last question would be: SHOULD I "RESTORE" THE DIAL OR SHOULD I LEAVE IT AS IT IS RIGHT NOW?
Every comment and suggestion will be highly appreciated.
The images:
More pictures:
Here I am showing the "scratch" in the mechanism lid, and the hit in the glass.
The last picture shows the box that the seller gave me. It is from a HAMILTON pocket watch.
Thank you very much again.:thumbsu:
I cant tell you who made the movement but the case is made by Pierre et Etienne Frainier and the mark on the watch was first registered in 1901 the designs on the case where often signed Frainier usually on a part of the foliage in the design is the back of the case decorated too ? Frainier cases in themselves are quite collectable they where a very small manufacturer. They where manufacturing watch cases from around 1864 to 1930, in a factory in Morteau  Fance close to the swiss boarder.
The movement is not a cylinder it is a jewelled  Swiss lever escapement  of reasonably good quality.
I would put the watch at no later than 1910
Edited by wls1971
spelling as usual
Goliath’s were used as travel watches and would normally sit in a case some plain or very decretive some silver.  Wis1971 is very correct; there isn’t much I can add. I think this is a 30 hour movement because of the way the train (wheels) are set out, most are 8 day. Do not do anything to the dial. The case is what is known as gun metal.  Red arrow depicts a replacement screw.
I like the look of it. personally I wouldn't do a lot to it apart from clean and service. I think it has a pleasant authentic patina to it. It is not the normal gold or silver pocket watch that people expect to be pristine. Just my thoughts.
Forgot to add I like the retro look of the movement. Not seen anything quite like that. The bridges shape/design look Swiss/French of about the period suggested, but with interesting differences. Obviously keyless so not super old. Interesting that the bridges are not bare brass as most I see are, and they have some nice simple decoration.
I have a few Swiss pocket watches from this period and they are all smaller, bare brass bridges, mostly undecorated. I am trying to get older keyed works. I am certainly no expert and have been looking at pocket watches more closely for about a year so far.
Edited by Vacherin
forgot a few bits
Hello everyone:
Wls1971 & Oldhippy:
Thank you very much for your kind attention and accurate information regarding this piece. It provides more light about the origin of it and in some way allow me to "speculate" the way this pocket watch end here in a flea market:
-Between 1865 to 1920, There were some families who showed up as aristocrats and followers of the extinct French empire in Mexico. These families were living in such fancy manors in the same Neighborhood, The "Rome neighborhood".
-With the pass of time these families were getting old and perish, leaving some distant relatives with a lot of debts and fully furnished "old houses (mansions)".
-The flea market where I did acquire this watch is located in "Rome neighborhood".
- (Oldhippy, this proves your explanation)  Somebody there at the flea market were selling a silver box with a "big hole". He said it was a "fancy kleenex dispenser".
Vacherin:
Thank you very much for your suggestion. I certainly will clean it and service the mechanism. I am planning to restore "in a museological way" the gun metal finish (just to erase the scratches in the mechanism lid and prevent more rust in the hinges).
TimFitz:
Thank you very much. :D
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
