You have the right number of screws and they are all in the right holes except the last two which now seem to be too ferking long. :pulling-hair-out:
Where is that angle grinder...?
That bloody watch is cursed.
I kept all the screws from the top seperate - all 6 of them.
Now two don't fit anymore. They don't fit if swapped either!
Green - Fit.
Red - don't fit.
The green in the top pring doesn't fit the bott sping either and the screw that came out of the hinge hole on the left is too thin now.
The two that hold the bridge have tapered heads so are obvious and different from the spring ones.
The one that hold the clip on the right has a shoulder
Edited by p2n
Sometimes it's better to ta a break. Forget the watches and do something else. Then maybe remember how it should be or where  the parts should sit.
Perfect suggestion.
J
