  • 1. Question
    Which of the following can aid you with picking up small parts where using tweezers may be problematic…
    • Pegwood
    • Rodico
    • Finger Cotts
    • Watch Oilers
    • Your Fingers
  • 2. Question
    Please study the picture above and complete the following statement…
    • The above components form part of the mechanism.
  • 3. Question
    Please complete this following…
    • The Going Barrel is made up of four components:
      • The Barrel
      • The
      • The Barrel Lid
      • The Barrel Arbor
  • 4. Question
    Please sort the following components into their relevant watch sections – hover over the image, click and drag to the correct section…
    Sort elements
    • KEYLESS WORKS
    • ESCAPEMENT
    • THE TRAIN
  • 5. Question
    Which of the following is true…
    • D5 is a watch oil typically used to lubricate watch escapement parts such as the balance end-stones and the escape wheel teeth.
    • D5 is a watch grease typically used to lubricate watch back gaskets.
    • D5 is a thicker watch oil used for heavier friction points such as the mainspring barrel or centre wheel pivots.
    • D5 Is a de-greasing agent used to remove old deposits of lubricant
  • 6. Question
    Watch escapements are designed to offer the two primary functions…
    The first is to allow the train of wheels to lock and be released
    What is the second?
    • It provides impulse or power to the oscillator.
    • It directly provides the gearing ratio to allow the hour hand to rotate 12 times slower than the minute hand.
  • 7. Question
    What is this?
    • A Cylinder Escapement
    • A Cylinder Drum & Barrel
    • A Fusee Escapement
    • A Fusee Drum & Barrel
  • 8. Question
    An Armoured Glass, made from perspex, is typically used with some types watch cases in order to provide a higher degree of water resistance. How is this achieved?
    • A special type of adhesive is used.
    • A metal ring provides extra tension.
    • Water pressure causes the glass to expand.
  • 9. Question
    Which section of the watch allows you to interface with the watch in order to wind the mainspring and set the hands?
    • Motion Works
    • Keyless Works
    • Escapement
    • The Train of Wheels
  • 10. Question
    Study the picture above – these are the parts which make up the Keyless Works section in a basic mechanical watch. But there is a missing part – which one?
    • Stem
    • Setting Lever
    • Yoke
    • Setting Lever Spring
    • Yoke Spring
    • Sliding Clutch
    • Winding Pinion
    • Setting Lever Screw
  • 11. Question
    Watch Escapement
    Watch Escapement
    Please complete the following statement…
    • The Pallet Fork locks and releases the escape wheel. There are two jewels installed into the pallet fork, these are called the ‘ stone’ and the ‘exit stone’.
  • 12. Question
    What is this tool used for?
    • For blowing air to dry parts
    • For applying oil
    • For applying a cleaning solution or de-greaser
  • 13. Question
    The HOUR HAND is fitted to the HOUR WHEEL
    What part is the minute hand fitted to?
    • Centre Wheel
    • Minute Wheel
    • Cannon Pinion
  • 14. Question
    Screen-Shot-2017-05-03-at-20.53.16-300x1
    The above mainspring has an s-shape to it. Why?
    • The additional reverse coil formed provides extra power as the mainspring unwinds.
    • The additional reverse coil formed is a by product of the modern manufacturing process.
    • The additional reverse coil formed stops the mainspring from slipping out of place.
  • 15. Question
    Select all the parts in the list below which belong to the Motion Works…
    • Hour Wheel
    • Minute Wheel
    • Centre Wheel
    • Cannon Pinion
    • Sliding Clutch
    • Ratchet Wheel
    • Setting Wheel
  • 16. Question
    The Cannon Pinion is directly fitted to which other part, and what does it drive?
    Choose from the following possible answers…
    • The cannon pinion is friction fitted to the Third Wheel and drives the Minute Wheel.
    • The cannon pinion is friction fitted to the Centre Wheel and drives the Minute Wheel.
    • The cannon pinion is friction fitted to the Centre Wheel and drives the Hour Wheel.
    • The cannon pinion is friction fitted to the Going Barrel and drives the Minute Wheel.
    • The cannon pinion is friction fitted to the Going Barrel and drives the Hour Wheel.
  • 17. Question
    Screen-Shot-2017-05-03-at-19.05.09-300x1
    What are these?
    • Spring Loaded Bars For Retaining The Crown & Stem
    • Spring Loaded Bars For Retaining Watch Straps
  • 18. Question
    Select ONLY the parts below which form part of the watch Escapement…
    • Balance Complete
    • Escape Wheel
    • Mainspring Barrel
    • Crown Wheel
    • Pallet Fork
    • Click Spring
  • 19. Question
    Please choose from the list below the common places you might find the manufacturers mark and/or calibre…
    • Under the balance wheel
    • The train wheel bridge
    • Barrel bridge
    • Stamped on the underside of the watch dial
    • Engraved inside the watch back
    • On the main plate under the dial
  • 20. Question
    C0296_pic1_cmyk.jpg.0c922beb02925545146a
    • Removing power from the mainspring in a safe and uniform manner so as to prevent breakages.
    • A professional tool for setting the hands on vintage pocket watches.
    • A tool for safely removing a friction fitted cannon pinion from its installed location.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
