I am currently working on a Mark IV Omega Speedmaster and found a jewel that was badly scored.  Since I couldn't work on it anymore until I get a new jewel, I decided to play with my microscope and camera.  Here is the chronograph bridge with the bad jewel circled.  There is an old case tube beside it for a size reference.  The second picture is of the jewel at 45x magnification.  I still need to work on my lighting to get better pics, but at least it works :)
C3134CCF-2B31-4674-818C-E803A130F1B6_zps
D4E102FC-AD07-472E-A055-4E8F1D29CBD7_zps
Great pics.
Probable: The old oil dries and mixed with dust and metal particles it forms a sort of paste and causes the damage to the jewel. Goes to show how regular service (clean the old oil away and re-lubricate) is essential. Too many owners have the opinion that "if it's not broken don't fix it" and this is the result.
Thank you all for the comments. The microscope is a 3.5x-90x zoom trinocular amscope from eBay. I tend to use it without any added lenses which yields 7x-45x magnification. It is more than enough magnification and still allows enough room to work. I just cannot say enough good things about it. I only wish that I had better lighting and could take better pictures. The lighting should be an easy fix and pictures will just take practice and experimenting.
I will see if I can get a picture of the winding gear where it was hitting the jewel. I am not truly sure why it would cause such scoring. The winding gear doesn't look as if it can be disassembled, so I am going to double check that it is functioning properly. This movement winds bidirectionally. Maybe it is fouling in one of the directions. I am also going to double check the end shakes. If anyone has any other ideas of things to check, I am all ears. Will be back later. Thanks!
Hi Guys,
I was able to take some more pictures for you all.  Hope they are what was asked for earlier.  I am not 100% sure, but I think that the winding gear (reverser) is bad or gummed up.  I have cleaned it twice and once in my ultrasonic cleaner.  The technical sheets that I have say to only oil the top and bottom under the metal disc.  I find that strange since the reversers in the 55X and others can be disassembled and you are supposed to oil the little satellite wheels.  When I put the freshly clean wheel on the satellite pinion and attach the bridge, the other winding wheels or rotor do not move.  When I apply a little amount of 9010 to the spaces indicated, the winding wheels will move every time I wind and the rotor will occasionally spin when mounted.  This reminds me of the eta reverser wheels when they are bad, unclean, or not oiled properly.  I really don't want to order a new one since the cheapest I can find is $70US.  I imagine that this is the culprit since the jewel is so badly scored.  I feel like the winding gear (reverser) is spinning every time the crown is turned, causing it to ride up and hit the jewel.  Just a guess though.  It seems like it should be held stationary and spin on itself when manually winding.  Anyway, here are some pics for you guys.  Some are with the scope and some are with the DSLR.  Thanks!!!!
35F848C3-5A8D-4041-AF9C-37F7228742E5_zps
50521730-3791-44D9-8563-53002C5AF8B4_zps
F91687FD-BDA7-454D-B947-0BB30AA6E5E2_zps
CADE8BB2-359F-4374-B19F-559121668269_zps
13282103-2FA2-41F1-9175-8FF83C219E38_zps
9EE13C9E-02A0-4190-B42F-6B93359B00C0_zps
362072A4-3F3E-4815-A552-F2924ECC1D9F_zps
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
