A .99 cent purchase . Guy said it needed a battery. Hmmm. Just a wind.
Don't think my photo is showing up? Will investigate further. Photo size may exceed limits. Anyway...99 cent Marvin from late 40's. Great piece. This is my first post and I'm looking forward to being here. I really want to be able to clean and work on my watches.
Photos to come !
Hi Gary,
Welcome to the forum.
That's a fantastic find for just 99 cents. It looks like it might even be an all stainless steel case too.
Looks like it won't take much at all to bring it into top order.
Welcome aboard from Scotland. I agree with Marc, a cracking find that should turn into a really piece when restored.
I can't believe Will missed that one!
Welcome! And - no - I only look at watches in the UK!
Thank you for the kind welcome. Actually I have another Marvin from that vendor and as they both work they are losing 3-5 minutes a day. I will be glad when I can disassemble and reassemble with nice cleaning and lubrication.  I am reading as much as possible and look forward to the next post!
I recently serviced a Marvin watch for my brother who had kept it in a draw for 10 years +. After a strip, clean and re-assemble it runs a treat , in fact in one position showed a reading 0 s/d.  Very impressed with the build quality & http://www.ranfft.de has a few to look at.
@Clockboy
They seem to be great movements. The other one is a little rough but still runs pretty well. I would like to add more to my collection.
I'll post a pic of it too later.
Hey Welcome from Brooklyn, New York! I love subsecond watches. I had a bumper omega with subseconds and sold it because I never wore it. Nice looking watch and look forward to hearing more from you
Today! Gains about 30 seconds a day. In need of a cleaning.
30 seconds is not too bad at all. The cleaning may remedy that. I've got two of my repairs under observation to try to get them regulated for optimal performance. Right now one is within 1 minute from quartz timie, and the other goes from 3 to 5 minutes off AFTER cleaning and oiling. I guess I would be OK with 30 seconds to 1 minute deviations per 24 hrs--yup.
JC
One of the Stargate Seikos I restored starter gaining about 10 min a day after cleaning and all. I thought being a Stargate it was giving me the time in another planet! :) When I looked closely there was a drop of oil shorting the hairspring. Once I cleaned the whole balance and re lubed, it started working fine....
So maybe on both cases, it is just the hairspring coils touching!
Edited by bobm12
I didn't think I would like to carry the pocket watch since I don't like things in my pockets but actually I have gotten accustomed to it quickly. I do feel "naked" without a wrist watch though...LOL!
  • 4 weeks later...
marvin's are great value...you will usually find the movements marked 3 adj or 5 adj. This means that they left the factory with additional work done to ensure that the run accurately!. Practically chronograph grade.
Also they are a true manufacturer and I have not come across any ebauches..(mechanism made by other companies like ETA, AS, FEF, FHF, ST) so they are quite high quality.
Be careful not to drop it as most of them date from the fifties and do not have any shock-protection at all.
Anil
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
