I've got a 17 Jewel Vitange Zentra pocket watch. I've been googling and not turned up anything about them.
I'd particularly like to identify the movement - The balance staff is bent and I want to try and find a replacement.
P4110003.thumb.JPG.62567756ad19183a7cb1f0d3880c616c.JPGP4110004.thumb.JPG.8f41c629c9f94db9b0e18bbf3159ef8c.JPGP4110019.thumb.JPG.c9cbee32af660bd3d2c0e8b52dfbedeb.JPG
All these photos and more HERE
The movement is a French made Parrenin probably a calibre H4.2 16 ligne they are listed on Ranfft so you should be able to check.
I used a Besfit book do a search on a Bestfit catalogue, you identify movements by matching the setting or keyless works parts to ones illustrated in the catalogue they are well worth buying look on Ebay for them. The dial side of the movement tells you more than the Bridges on a watch when trying to identify a movement.
I'll keep my eye out for one.
The Ranfft page suggests the balance staff is a "U936". This doesn't seem to be a universal size code. The only site I can find that uses them is Flume.de and they don't list the 936. Do you know of any other sites or a table of equivalents?
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
